So i have a 03 ram 1500 with a 4.7 v8 that was put in 4500 miles ago the first 1500 where on the factory oil, then i put in GSGB for 3k and its time to change. i have a stash of Pennzoil platinum that i want to use but i have gotten advice that i should go 7k on dino so my rings set. so is 4500 enough mi for the rings to set or do i need to go buy more dino juice. what will happen if i put the pennzoil in to early?
thanks,
-sam
thanks,
-sam
