It is not a cureall but it did solve what we think was a sticking VVT control valve problem. It does appear to have some extra cleaning ability.
I don't recommend using any OTC additive willy-nilly unless you have a specific problem to solve.
I would also add that when you use an additive and you think your problem is solved, drain it and refill with a good quality oil.
To answer Shannow's question, I don't know of any OTC PI package in a can that will do what he wants.
In formulating any oil, one has to examine the type of base oil (it's viscosity and what is already in it), add the PI package, test viscosity, add a VII to get close to the viscosity needed, test again, and then tweak if necessary.
