Last year I bought a small boat that came with a 7.5 hp Ted Williams outboard(basically a tecumseh mower engine).I took it out a few times,probably less than 3 hours use in total.A series of family emergencies put an end to my fishing last year.The motor ran okay, a bit buzzy and hard to start.I'm used to Evinrudes and Mercury,never had an air cooled before this.
I pulled the motor out today to give it a tune up.I drained out the stinky dark black oil out of the foot and refilled with Pennzoil Marine Lube.Pulled out the spark plug(a NGK CS5) and took a look at it....black and sooty with almost no gap.No kidding. I tried to measure the gap on a gapping disc and the disc would not fit on the lowest end .So the gap was less than .017.No wonder it was hard to start and seemed to burn rich.(from my research that plug in no way applies to this motor)
I replaced the plug with an AC R45S which is the modern version of the recommended plug and gapped to .035.
I took the motor and put it in a barrel of water and started yanking on the pull rope.Once I got the tank(filled with 32:1 mix) pressurized I sprayed a bit of starting fluid near the carb and got it fired up.Played with the choke and lean-rich setting and got it idling pretty good,put it in gear let it run about 45 minutes on a low setting.I ran it up on "fast" as marked on the tiller handle and it seemed to develop a "skip" and I backed off the throttle.Anyone have any ideas about this "skip"?
Once the engine was warm I turned it off a few times and it restarted easily.Hopefully I'll get out on the water in the next week or so.
