I went home to see my parents this weekend, driving my Element. I live in Chicago, but grew up in northeast Ohio, so I make this trip several times a year.
I use Fuelly to track my mileage and routinely find that I get significantly better gas mileage going east compared to coming back, going west. There have been times where I'll drive home, do an oil change, transmission fluid change and top off the tires expecting better gas mileage, then find out that I actually did worse.
I use cruise control almost exclusively (even though I know that it isn't the most fuel efficient method, especially on hilly terrain).
This past weekend, I measured 26.5 MPG heading east (engine warm, get gas, drive, pump again and calculate) then on the way back, I got 22.9 MPG. Carrying the exact same load. No work was done on the car while at home. I think I got my especially good gas mileage since it was cool enough on the drive out that I didn't need A/C. I used A/C about 75% of the time coming back.
Same trip back in May, 25.0 MPG eastward, 22.9 coming back. Most likely used equal amounts of A/C each way.
Some other things to note:
These are the factors I can think of:
I'm not too worried that there's anything wrong at all, just wanted to see if I'm missing anything.
Thanks for your thoughts!
- Route taken: I-94 out of Chicago to I-80 the rest of the way
- Chicago Elevation: ~600ft
- NE Ohio Elevation: ~1,066ft
- Car downshifts up a grade about 4 times per trip eastbound
- Car downshifts up a grade 8-10 times per trip westbound
- My typical drive eastbound is at night, while my return is afternoon
- Gas quality (eastern Indiana gas vs Ohio gas)
- Headwind vs Tailwind
- Something weird with the hills having less grade going east compared to west
- Ambient temp/Sun load on the car affecting the engine during the hot afternoon
