Originally Posted By: gathermewool
Looks really good! I bet it was delicious.
We just began our first horticultural attempt with cayenne peppers. Only six plants, and only one pepper per plant, but that's ok with us.
Any recommendations for cheap, natural pesticides? We've tried soapy water, pepper, etc, but the buggers don't seem to be bothered by it. The leaves are even turning a bit yellow...
First off, what soap to water mixture are you using and how often are you using it? I use one half cup per gallon of water and spray once a week unless it rains, then I spray after every rain.
Secondly, try black pepper and garlic. Simply sprinkle it liberally over and around plants, just make sure to be upwind and wash your hands thoroughly after sprinkling.
Third, have you tried tobacco spray? Take one cigarette and drop it in a gallon jug filled with water. Allow to "brew" in the sun for several hours, (much like sun tea). Strain and pour liquid into hand pump sprayer. DO NOT USE THIS ON TOMATOES AS IT WILL KILL THE TOMATO BUSH.
What you have to remember is that while chemical pesticides kill the bugs, most organic sprays simply make the bug go away as the spray either tastes bad or smells bad. When the rain washes it off, the bugs return.
One other thing about your yellow leaves, what kind of fertilizer are you using? Yellowing leaves is an indication of nutrient deficiency. If you want to stay organic, manure is always a good choice.
