2016 Volkswagen Tiguan Oil filter - Weird Design?
by FordBroncoVWJeta
Today at 02:21 AM
New old ride
by SEBZX79
Yesterday at 11:25 PM
Motor Trend Visit with Valvoline
by tenderloin
Yesterday at 10:46 PM
Fixing Tractors a no-no, Are cars next?
by user52165
Yesterday at 10:38 PM
Cosmetic only or replace
by ram_man
Yesterday at 09:55 PM
Wooden Motorcycle Piston from Vietnam
by KeithS_NW_Ohio
Yesterday at 09:49 PM
Castrol Edge for hard-driven turbo + DI
by Atomic
Yesterday at 09:27 PM
2001 Camry LE V6 - Synthetic ATF Recommendation
by 01CAMRY
Yesterday at 08:39 PM
Delo 400?
by Sealbilly
Yesterday at 07:17 PM
Noob question about chain maintenance
by JeepWJ19
Yesterday at 07:00 PM
Rural King Full Synthetic Oil Sale...
by AnthemBassMan
Yesterday at 05:16 PM
Mobil 1 EP oil filter - Cross Reference
by Kung_Faux
Yesterday at 05:08 PM
rfabrocini, Tobin28, r0k, KNA, Roanoke6370
58598 Registered Users
31 registered (Charlie1935, chrisri, Boomer, bullwinkle, bmod305, denver1, 1 invisible), 675 Guests and 17 Spiders online.
58598 Members
66 Forums
252250 Topics
#3435830 - 07/25/14 09:44 PM High Pb with 5w-40
sdan27 Offline
Loc: Michigan
I've done a few oil analysis with a 7.3L powerstroke engine I swapped into my 94 F250. Before I put the engine in I installed new bearings. The first four analysis were with Schaeffer 5w-40 and then I did two with Service Pro 15w-40 and then I did one with Delo 400 5w-40. The lead numbers are noticeably higher with all the 5w-40 results. Do you think this is something I need to worry about? I like using the 5w-40 in the winter as it helps my HEUI system run a lot easier.
Miles 5100, 10200, 13800, 9650, 5010, 9371, 9777
Oil Sch, Sch, Sch, Sch, SP, SP, Delo
Iron 25, 31, 37, 35, 18, 30, 38
Chrm 0, 0, 1, 0, 1, 1, 1
Alum 2, 1, 4, 3, 11, 15, 6
Copp 6, 10, 15, 10, 5, 7, 6
Tin 4, 6, 7, 4, 5, 7, 6
Lead 13, 23, 31, 35, 11, 17, 34
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#3435838 - 07/25/14 09:51 PM Re: High Pb with 5w-40 [Re: sdan27]
Chris142 Offline
Loc: apple valley, ca
whats your silicon numbers?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3435928 - 07/25/14 11:42 PM Re: High Pb with 5w-40 [Re: sdan27]
sdan27 Offline
Loc: Michigan
42, 37, 43, 23, 8, 8, 7. I figured that the high numbers came from rtv, gasket material when I put the engine back together.
#3435966 - 07/26/14 12:47 AM Re: High Pb with 5w-40 [Re: sdan27]
Chris142 Offline
ya the single digit silicon isnt it.
87 F250 delo 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#3436013 - 07/26/14 06:08 AM Re: High Pb with 5w-40 [Re: sdan27]
gathermewool Offline
Loc: New England
Any major difference in the detergent packages?
What's the difference in the 100C Cst?
It might just be a difference in chemistry composition causing non-detrimental spikes in lead. Just spit-balling
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#3437945 - 07/27/14 10:16 PM Re: High Pb with 5w-40 [Re: sdan27]
sdan27 Offline
Loc: Michigan
100 cst 13.1, 13.6, 13.8, 12.8, 12.7, 13, 12.2
Some shearing but only down to a 30w at the most.
#3452830 - 08/11/14 08:15 PM Re: High Pb with 5w-40 [Re: sdan27]
sdan27 Offline
Loc: Michigan
Do you think the lead numbers are something I should be concerned with then? Do you think its coming from my bearings or somewhere different.
#3453054 - 08/12/14 04:48 AM Re: High Pb with 5w-40 [Re: sdan27]
dnewton3 Offline
Loc: Indianapolis, IN
Pb in those engines generally has one source; bearings. I cannot tell you which one(s). Could be the ones you replaced; may not have seated well and now wearing. Or could be an unrelated bearing (one you didn't replace) that has finally got into damage. When you mention "new bearings", which ones? Crank, rod, cam, turbo?
At first blush, it seems the Cu went up and Pb followed, but when taking OCI duration into account, the numbers are not staggering.
Generally, the only metal that will accumulate with miles is Fe; the others should tend to have a bit of wear and then stagnate over the OCI.
Everything you've tried has been a 40 grade. If you want better starting, why not try a 30 grade? Perhaps see if that will do as well. I'm not suggesting this because I think "thinner" will do anything for the wear; it's just a nod towards your concern for winter. At this point, if you try a 30 grade and the wear does not get worse, and it helps in winter starts and idling, then you can settle on one fluid, pick one OCI duration, and then track the wear. You cannot really track wear well jumping around in fluid and OCI duration.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3453766 - 08/12/14 05:17 PM Re: High Pb with 5w-40 [Re: sdan27]
sdan27 Offline
Loc: Michigan
I did the main and rod bearings. I used Clevite bearings. I'm going to see if the numbers stabilize a little more with the 15w-40 and if it does I'll probably try and find a 10w-30. Most HD 10w-30s available where I live are semisynthetic so we'll see if those bring up my lead numbers too.
