Originally Posted By: meep
those rotors are freakin beautiful. I completely agree with choice of slotted while avoiding drilled. coincidentally, the raybestos rotors I have purchased are slotted as well. it's the at-300. the slotted rotors + proACT pads made a huge difference in my wife's mdx.... much "deeper" pedal--- you'd swear after that brake job that the car could do an "endo" on the front. The brakes don't run out of breath as pressure increases.... they just continue to bite more and more. I've never panic-tested them--- they are that strong. I *know* they will out-brake the tires.
Meep,
Not sure the part # for yours. I have a set SP performance slotted for my '03 Sequoia. I got them WAY back when Tundrasolutions had a group buy going. I loved them with the Hawk LTS pads. Huge improvement in brake feel stopping power. If you read on raceshopper it says that the slotted may cause a slight "whirrrr" under heavy braking. At 6000lbs and wife with heavy foot, every braking is hard braking. The noise drove her nuts. I was OK with the whirrrr from the brakes but the WHINING noise from her was just way too much.
There sitting in a box, have about 2k miles on them. Pay for shipping from NY and you can have them if they fit. Currently I run stock rotors and Hawk LTS which is much better than the carquest premium pads the shop put on last time. They $UCKED and you just never got that bite that the Hawks provide.
Part number on the box is T52-267 slotted
Meep,
