What happened to Anco wiper blades
by grampi
05/27/16 07:21 AM
Full brand oil filter
by RRLJR
05/27/16 05:31 AM
Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
83 registered (badtlc, alarmguy, Astro14, 901Memphis, 69GTX, AirgunSavant, 5 invisible), 1621 Guests and 301 Spiders online.
57996 Members
66 Forums
249472 Topics
Page 5 of 5 < 1 2 3 4 5
#3344215 - 04/16/14 07:12 AM Re: The confusion around BMW M oils continues [Re: riggaz]
gatorfast Offline
Loc: Fla
Originally Posted By: riggaz
Not sure it would do the longlife oil drain interval would it?
Yes, TWS is used in M cars with drain intervals of 15k miles (though most change before that). It would not be rated LL-01 though due to the weight and characteristics of the oil (i.e. the special 10w-60 is not suitable for use in regular 3 series, 5 series, etc).
E90 M3
#3344351 - 04/16/14 10:19 AM Re: The confusion around BMW M oils continues [Re: riggaz]
dparm Offline
Loc: Chicago, IL
Originally Posted By: dparm
Castrol wouldn't bother paying for TWS to get certified as LL-01 since it was never intended for widespread use. It would easily pass, in my opinion.
It did the 15k intervals in my car just fine. The sump and filter are quite large, which helps.
2011 BMW M3 sedan ZCP
#3344430 - 04/16/14 11:17 AM Re: The confusion around BMW M oils continues [Re: dparm]
riggaz Offline
Loc: England
Ah ok, makes sense, like the other chap said, must be a viscosity thing.
#3437395 - 07/27/14 01:50 PM Re: The confusion around BMW M oils continues [Re: dparm]
bimmerdriver Offline
Loc: British Columbia, Canada
The factory interval is 15k, or whenever the car tells you to change it.
Most guys opt to split the difference and change it every 7-8k.
When I was shopping for an E46 M3 last summer, I looked at several that were given 20k km oil changes. All of them had dark brown deposits inside the valve cover and one even had sludge and rust on the dipstick. It had 59k kms and had been treated to only 2 oil changes up to that point. The car I ended up purchasing was low mileage, only 11600 kms and had been given numerous oil changes (based on time, not mileage). I bought the car 11 months and 3500 kms ago. The PO changed the oil right before I bought it. The maintenance indicator is still saying over 16k kms before the next oil change. There is no way I will leave it in that long. It would take at least a couple more years to accumulate that much mileage. I will be changing the oil in a couple of weeks. I don't know what BMW was thinking making a 15k mi or 20k km oci recommendation. I think 7-8k mi or 10k kms mileage or maximum of one year duration makes much more sense if you want to keep the engine clean. My mechanic says this is a good idea for the N54 and N55 engines also, due to amount of fuel that gets into the oil.
2002 BMW M3 (mine)
1997 BMW 328is (sold)
2002 MB ML320 (hers)
2004 VW GTI (son)
#3437402 - 07/27/14 01:54 PM Re: The confusion around BMW M oils continues [Re: bimmerdriver]
Quattro Pete Offline
Loc: Great Lakes
Well, out here in the US, BMW is including all maintenance at "no cost" during the 4-year/50K mile warranty period, so they don't want to be providing these services too often. That's why also the trans fluid become a "lifetime" fluid all of a sudden.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3437406 - 07/27/14 02:05 PM Re: The confusion around BMW M oils continues [Re: dparm]
Mahle is actually the big supplier for BMW OEM filters, from what I can see. Hengst and Mann of course have them too.
I'm pretty certain it's correct that Mahle is the OEM, at least for my S54 engine. Here is a link to pic of the OE BMW filter. Here is a link to a pic of the Mahle filter. Here is a link to a pic of the Mann filter. I don't think there is much doubt the Mahle filter is the same as the BMW filter. It seems to be more robust than the Mann filter. I wouldn't hesitate to spend a $2 more to get the Mahle over the Mann.
2002 BMW M3 (mine)
2004 VW GTI (son)
#3437408 - 07/27/14 02:08 PM Re: The confusion around BMW M oils continues [Re: Quattro Pete]
I guess if you only care about the car during the warranty period, it makes no difference what happens after. If you want the car to last beyond the warranty period, it's another matter.
2002 BMW M3 (mine)
2004 VW GTI (son)
