Originally Posted By: Mykl
Within 100 miles of where I live there are multiple dealerships selling Ecoboost Fiestas for $15,000. If you need a cheap, efficient car and you insist upon buying new this is as good an option as any.
The Mirage makes a great argument for itself, but from what I can tell the Fiesta's case is that it's a nicer, likey better screwed together car.
I would love a car like that. So would other people. Its selling well, about as well as the ST hot-rod version. Someone at Ford had the good sense not to offer it with an automatic.
As you point out, the price is competitive if you can find one. A hatch with the (surprisingly) low-priced comfort package has a street price of maybe $17K. Not bad. Based on the power to weight ratio, it should cruise easily to 80 mph. It is however, a full tenth of a second slower to 60 mph than a 1982 Corvette. How did we ever manage back then?
http://media.caranddriver.com/files/last-of-their-kind-corvettes.pdf
A 7yr 100K extended factory warranty is only $700, so you can be protected that way.
https://www.floodfordesp.com/esp_plan_co...Submit=Continue
The car has about a 4 quart oil sump. That's awesomely large, considering how little surface area has to be lubricated. That helps with service life if oil changes are a bit haphazard. This forumite pulled a TBN of 4 (Blackstone) on a 7,000 mile OCI.
http://www.bobistheoilguy.com/forums/ubb...C_5#Post3393481
I realize that the ideal on this forum is that a car should be able to exceed the speed limit on the interstate at fast idle, but there are other points of view.
