I picked up this car a few months ago. She went into the stealer for a noisy engine problem last week. I pulled an oil sample via the dipstick tube before she went in. There was a TSB for wrist pin bearings failing and causing noise and cylinder wall scuffing. The stealer replaced the water pump and belt, under warranty, as the source of the noise and confirmed the cylinder walls were all A-ok.
I received this UOA today.
The dealer also changed the oil with Mobil-1 Formula M 5w40, and a fresh filter.
Quiet as a mouse now she is.
[img:center][/img]
[img:center][/img]
