Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
Carlson Slide Pins
by SavagePatch
08/27/16 08:07 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
52 registered (3800Series, A310, B320i, 69GTX, Astro14, 901Memphis, 6 invisible), 934 Guests and 33 Spiders online.
58943 Members
66 Forums
253655 Topics
Page 1 of 2 1 2 >
#3437108 - 07/27/14 08:24 AM Time to replace the bicycle chain...
mrsilv04 Offline
Loc: Illinois
I've determined that it is time to replace the chain (I'm now seeing that dreaded extra stretch). The bike currently has a Shimano HG-73 (9 speed) chain on it.
I'm assuming that it is best to simply replace what is on there, with another one of the same?
I don't know how many miles that this chain has on it, as I bought the bike used... but is at well over 1000 miles with me.
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#3437125 - 07/27/14 08:43 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
mcrn Offline
Loc: FL
You going road riding or mountain bike?
#3437135 - 07/27/14 08:56 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
mrsilv04 Offline
Loc: Illinois
Sorry... road.
#3437141 - 07/27/14 09:05 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
mcrn Offline
Loc: FL
Well I do not know about road but I like KMC chains for mountain bike.....they have a link that makes the chain very easy to come for cleaning plus they seem very durable and quiet.
#3437181 - 07/27/14 10:11 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
Darwin1138 Offline
Loc: Slimy Mudhole
I will use the same brand, the rule of thumb is to replace every 2000 miles, so it is within the limits of normal wear.
Don't forget to check your sprockets for wear, Are you hearing any noises or the chain is skipping some speeds?
And don't fall for those titanium (golden) chains, they are not worth the value.
0W-20 or death!
#3437229 - 07/27/14 11:23 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
Ram01 Offline
Loc: New York Queens
Must of got the chain from GM smile
#3437255 - 07/27/14 11:58 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
lpcmidst128 Offline
Loc: San Francisco, Calif.
I like the SRAM chains, it has as master link (they call it PowerLink) for easy installation. You would need to use a chain tool to remove links to get the right chain length. For checking chain stretch I use the Park Tool chain wear indicator tool.
#3437274 - 07/27/14 12:21 PM Re: Time to replace the bicycle chain... [Re: mrsilv04]
Taildragger Offline
Loc: SW Florida
As stated above, look at your sprockets closely.
04 F-150 5.4
73 Big Block, 4sp Corvette
15 Mazda 3
Couple of airplanes
#3437354 - 07/27/14 01:22 PM Re: Time to replace the bicycle chain... [Re: mrsilv04]
mrsilv04 Offline
Loc: Illinois
Sprockets are good. Rear cassette has recently been apart, cleaned, and re-installed.
#3438185 - 07/28/14 08:20 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
Wheel Offline
Loc: Upstate NY
I really like the Wipperman nickle plated chains. It has the connex link for no tool removal, which helps at cleaning time. I've run these for my last 2 chains, as has my son. They hold up well.
#3438841 - 07/28/14 07:37 PM Re: Time to replace the bicycle chain... [Re: mrsilv04]
UG_Passat Offline
Loc: NJ
Originally Posted By: mrsilv04
Sorry... road.
it really doesn't matter if it's road or MTB. Same chain.
there are exceptions like the SRAM XX1 chain. It is best to use the SRAM XX1 specific chain on the XX1 chainrings, vs trying to use a Red22 (road) chain.
I personally use KMC chains.
Edited by UG_Passat (07/28/14 07:38 PM)
#3448391 - 08/06/14 09:16 PM Re: Time to replace the bicycle chain... [Re: mrsilv04]
mrsilv04 Offline
Loc: Illinois
Finally got the chain replaced tonight... and WOW, what a difference!
The first chain that I ordered was lost courtesy of the US Postal No-Service. So, I lost a week there. Ordered a second chain, and it arrived tonight.
Installed in about 10 minutes. Should have taken 5, but I wasn't in a big hurry. Took it out for a little trial run (didn't want to ride far, as it was after dark), and what a difference. Nearly feels like a completely different bike.
I went ahead and put a Shimano HG-73 back on it. I didn't see a whole lot of reason to change at this point. Got one for $24 shipped, so that was fine as well.
The new chain was lubed nicely, right out of the bag. Next, I'll have to research the proper products and technique for lubrication, as this is now a new chain, and I want it to last.
#3448667 - 08/07/14 09:01 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
mrsilv04 Offline
Loc: Illinois
From what I've read, a new chain is lubed as good as it will ever be... and to just enjoy it while it lasts (which could be hundreds of miles... YMMV).
So, I guess it is like the "new car smell".... enjoy it while it lasts.
#3449651 - 08/08/14 10:18 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
gizzsdad Offline
Loc: Iowa
From what I've read, a new chain is lubed as good as it will ever be....So, I guess it is like the "new car smell".... enjoy it while it lasts.
True! Then you'll probably want to go this way:
http://www.amazon.com/Dumonde-Tech-Bicyc...monde+tech+lite
#3455210 - 08/14/14 11:42 AM Re: Time to replace the bicycle chain... [Re: mrsilv04]
Saab9000 Offline
Loc: Florida
To really take it through its paces, put it in the small chainring and one of smaller cogs and get out of the saddle and really crank on it. If it skips, your cogset is worn. Be careful, you can lose you balance and fall.
Page 1 of 2 1 2 >
