Any audio gear junkies here?
by BeerCan
07/27/16 03:45 PM
FRAM XG7317 Cut Open After Street and HPDE Use
by HX520W
07/27/16 03:05 PM
Emergency declared on 2 California wildfires
by HTSS_TR
07/27/16 02:46 PM
Scratched interior plastic woodgrain trim
by TmanP
07/27/16 02:32 PM
Kia Sedona oil leak
by surfbum
07/27/16 02:19 PM
Castrol Australia's take on the issue with Zddp
by FordCapriDriver
07/27/16 02:09 PM
A Car Dear to my Heart - Gordon Murray F1 Designer
by HTSS_TR
07/27/16 02:08 PM
Need clarification regarding toe alignment.
by ST2008
07/27/16 02:04 PM
Engine Oil in Crusader Engines
by carverguy11
07/27/16 01:30 PM
How did your pro-rated battery warranty work out?
by CharlieBauer
07/27/16 12:56 PM
what grease every one using on ball joint ....
by MetalSlug
07/27/16 12:48 PM
How's Spectro oil?
by jkhawaii
07/27/16 12:45 PM
uicgrad, snydercn, surfbum, Tmemz4, woollum86
58613 Registered Users
91 registered (Al, Alfred_B, AlienBug, ABerns, 8o8is, AIRJAC3, 6 invisible), 2016 Guests and 12 Spiders online.
58613 Members
66 Forums
252324 Topics
#3435051 - 07/25/14 08:28 AM Rotella T6 5w-40, 13,015 mi., 2003 Jetta ALH
R80RS Offline
Loc: Wisconsin USA
The vehicle in this report is my primary commuter, and sees 90 to 120 moderate highway miles daily, with longer interstate trips from time to time. It never sees trips of less than 15 miles.
The oil filter in this interval was a Mann HU 726/2 X.
The 1/2-quart of make up oil was added about halfway through the interval, or about 7,000 miles before the sample was taken. Total sump capacity is 4.8 quarts.
For some historical context, the oil in the column dated 10-6-13 was T6 and in the 3-9-14 interval it was Amsoil HDD 5w-30. I notice an increase in some additive elements (Zn, P, Mg, allowing that the increased Ca may be carryover from the Ams HDD) between the T6 used in the 10-6-13 interval and this one. Did SOPUS fortify the add pack of T6 or is something else going on?
What's the consensus opinion on the lead level Blackstone flagged? How often do these trends resolve themselves (trend down) versus indicate a serious problem?
Any other comment or insight is welcome!
2004 F150 228k mi. Pennz Plat HM 5w-20, Fram Ultra
2003 VW Jetta TDI, 221k mi. Amsoil HDD 5w-30, Mahle
#3435072 - 07/25/14 08:54 AM Re: Rotella T6 5w-40, 13,015 mi., 2003 Jetta ALH [Re: R80RS]
A_Harman Offline
Loc: Michigan
A lead reading of 8 is not by itself a concern. If it's a spike, it's not a very significant one. Watch how it trends in subsequent UOA's.
You should be able to extend the OCI's significantly judging by the TBN of 5.6 at 13k miles. RT6 starts with TBN of 10.6, and Blackstone recommends oil changes at 1.0, so there is still a lot of life left in that oil. Try extending the next OCI to 16k. I think it could even go much further than that.
Edited by A_Harman (07/25/14 08:55 AM)
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3435169 - 07/25/14 10:15 AM Re: Rotella T6 5w-40, 13,015 mi., 2003 Jetta ALH [Re: R80RS]
webfors Offline
Loc: Great White North.. eh
Nice report. Strong FP, TBN, maybe some thickening going on with the visc?
If you're lead continues to trend with longer OCIs I would throttle back to ~12k.
15 Civic, AFE 0w20, FU OF
13 Dodge GC, VWB 5w20, Purolator OF
13 SFV650, T6 5w40, OEM OF
07 VS800, OEM 10w40, K&N OF
Small engines; RT5 10w30
#3435249 - 07/25/14 11:54 AM Re: Rotella T6 5w-40, 13,015 mi., 2003 Jetta ALH [Re: R80RS]
scurvy Offline
Loc: Chicago IL USA
T6 has always been IMO the best bang-for-the-buck TDI oils for non-CR engines. Great looking report, you should consider running it even longer.
Lead is a minor spike, might be from a particle streak through a bearing. I wouldn't worry about it unless it continues to trend upwards over the next few UOAs.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
