Porsche Panamera oil change Redline 0w40 or M1 0w4
Ndx
IL
Hi Guys,
Current fill in wifes Panamera is 0w40
About 6000km on it
I'm leaving to chicago on Saturday and thinking about doing oil change 2500km total trip.
I have case of Redline 0w40 can I just use that or should I go buy M1
Redline would stay for 5000k and then Uoa but I don't want to cause extra wear...
Mobil 1 0w-40 for sure.
There's no sense in a non-approved oil unless you know you have a problem that you know it can fix.
There is one thing to fix.. How noise these engines are lol
Either one would work just fine, but for a car under warranty I would be inclined to stick with Porsche-certified oils.
I would change the oil after the road trip.
+1 Why the need to change it? Another 2500km highway trip is nothing. Just keep it topped off.
I guess she isn't fond of the Porsche engine note, huh..
I guess she isn't fond of the Porsche engine note, huh...
+2
+2
+3
Besides, these engines have pretty generous oil sumps.
If the choice was between M1 SM 0W-40 (still available in Canada), M1 SN 0W-40 or RL 0W-40 I'd recommend M1 SM 0W-40.
But since you have the RL oil I'd pickup a couple of litre of TGMO 0W-20 to dilute the RL by 1/3rd to make a light 0W-40 with a more appropriate ZDDP level while bumping the VI to almost 200.
Whatever you do don't use up all of the RL 0W-40, I still want to buy a quart or two from you.
Cheers
Let's see.
6K KM is only 3600 miles.
Why would the oil need to be changed?
This car apparently doesn't see a lot use measured in either kilometers or miles.
Red Line for 3K miles would be a waste of oil.
M1 0W-40 is also only $22.46/jug at Walmart in this area.
Change the oil as recommended by the manufacturer.
For an expensive engine still under warranty, use what Porsche recommends on the recommended drain intervals.
This isn't an old Hyundai or Ford with which one might experiment freely.
Thank you I left oil in
Unless the RL can mercifully change the way that sausage looks, you should keep running M1, as Porsche specifies. And with the mileage you've got, there's no benefit to changing it now. The advantages of M1 are increased friction protection and longevity, recall it's synthetic, so the OCI rules change. At least you should get that part.
(I guess I am not the ONLY one who's NOT enamored of the aesthetics of the 'Panzerwagen'.
When I like how a car works, I end up liking how it looks.
If it weren't for that, I'd completely agree that the Panamera is ugly as sin.
As things stand now, I think it's gorgeous.
I call this the "Supra MKIV Turbo syndrome", as all of it's fanboys seem to think it is THE best looking bit of machinery EVER produced, bar NONE, due to it's modifiable performance potential.
That being said, I do understand your post above, to a point.
Originally Posted By: dennishiip
Redline is superior to M1
For track use no doubt but for everyday i'm not so sure. Guys here use Motul 300V but only with short OCI. Apparently these kind of oil don't fight acid build up very well.
