Originally Posted By: gathermewool
Well, I'M not made of money. If the coolant is good for 100k, oil for 10k, ATF for 40-50k,then why would any one waste money by changing at less than half that frequency? Each by itself may be inexpensive (if Did,) but it adds up.
IMO, regardless of cost, I feel that anything that's not needed is a 100% waste of money. It's like buying something, anything on sale that you just don't need.
I'm with you. I've run the FF AF to the time for the Honda TB/water pump service, then subsequent 50-60k. And, I've only ever done 'single' ATF d&f's at ~25-30k intervals on the Honda's I maintain.
The 01 Civic went to 60k on the FF ATF, now that was before I joined bitog so I might have shortened that up to 25-30k miles as I've done on my Accord. But, check the 01 Civic AT on car compliants.com and now with ~210k on original AT and still shifting fine (knock wood). And the greater heresy may be using Maxlife and even some Castrol IMV after Z1 superseded.
That said if I had to pick, imo the trans service d&f's are significantly more important than more frequent than recommended AF d&f service.
