Originally Posted By: Phishin
Originally Posted By: Jarlaxle
That assumption is based on the fact that Suzuki builds and WARRANTIES the Burgman with 3k oil changes.
I'm spinning 7000-7800RPM on the highway.
Thanks cool. Honda does the same thing. I'm sure your Burgman will last until at least until the warranty period is up. After that, who knows. That's all Suzuki cares about....getting you past the warranty period with minimal service calls/claims.
I'm sure you're fine with 3000 mile OCI's on the Burgman. What is the oil capacity? What oil do you run?
On my Ruckus, I spend 90% of the time between 9-10k RPM's. The little 50cc engine is water cooled, but I added an oil cooler. That's helped raise the oil capacity from 0.6 quarts to all of 0.8 quarts. LOL!!! Plus, I have no filter.
I'll probably run the synthetic 10W-40 MC oil that Suzuki recommends, it takes about a quart and a half with filter change. There are plenty of Burgman owners with high miles using the factory OCI...highest I recall seeing was just over 100K on a 400, 179,000 miles on a 650. The AN400 redlines at 9000RPM and is perfectly happy to spin 7000-8500RPM for hours! (Many owners do just that!) These engines are DESIGNED to be revved.
