Clay Grease
by SR5
2 minutes 24 seconds ago
Which M1 oils are true synthetics
by FordCapriDriver
29 minutes 30 seconds ago
That's unfortunate...or maybe bypass filtration?
by linksep
Today at 02:24 AM
Over Oiling
by mjoekingz28
Today at 12:59 AM
Sweden Trials Electric Higway for Trucks
by Y_K
Today at 12:07 AM
17 yo deutsch filter?
by robo339
Yesterday at 11:07 PM
Ford Focus wrecked
by tig1
Yesterday at 10:13 PM
Valvoline Maxlife vs Supertech Synthetic vs QSED
by mazdamonky
Yesterday at 09:56 PM
Lexus seats in a Camry
by Nick1994
Yesterday at 09:52 PM
shop rechecking work after front end parts replace
by motor_oil_madman
Yesterday at 09:50 PM
M1-EP vs vanilla M1
by Atomic
Yesterday at 09:29 PM
Supertech Synthetic and Citgo
by RRLJR
Yesterday at 09:28 PM
Josh_Westwood, Brogan, Superlatives, Ruturaj, derfderfgoose
58280 Registered Users
30 registered (car51, b1amgm47, beavis87, dec219644, Boczech, 4 invisible), 794 Guests and 10 Spiders online.
58280 Members
66 Forums
250858 Topics
#3432516 - 07/22/14 04:50 PM Campy crank threads L. or R. thread?
daves66nova Offline
Loc: los angeles
I'm planning to disassemble my bike and i've read that some crank bolt threads are opposite,meaning counterclockwise tightens them. Does anyone here know what they are? I have Camy Nuovo Record. thanks
THIS SPACE FOR RENT, PLEASE PM ME.
#3432535 - 07/22/14 05:06 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
Wheel Offline
Loc: Upstate NY
According to Barnett's Manual, ALL crank bolts are regular right hand thread. Bottom brackets (except Italian threaded ones) and pedal axles are the usual ones that use left hand thread at all.
Theory was that regular movement of the components could cause loosening. I can't say I've seen that on the one bike I have with a bottom bracket threaded that way.
#3432594 - 07/22/14 06:06 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
oliveoil Offline
Loc: snow and sun
The bolts that hold the crank arm on are 14 or 15mm and are regular right threaded. But you need a "crank arm puller" to take the crank arms off. Then the Bottom bracket (BB) can be disassembled. You will need some bottom bracket tools also. Any bike shop can sell you these tools. The left side of the BB, the non drive side, as you are sitting on the bike looking down, is normal right hand drive and this is the only side that needs to be removed when overhauling the BB. Hope this helps.
#3433527 - 07/23/14 03:31 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
dailydriver Offline
Loc: Bucks County, Pa.
It's been a LONG time since I've had/worked on regular, old school style Campy cranks and bottom brackets.
I always remember having to use at least the red LocTite on the crank bolts in order to hold them in place, and not loosen up to the point that they destroyed the softer than the axle, tapered crank openings.
I still have my Campy "peanut butter" spanner which was used on these bolts amd also my track bike's Campy hub bolts. wink smile
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3433953 - 07/23/14 11:21 PM Re: Campy crank threads L. or R. thread? [Re: oliveoil]
teddyboy Offline
Loc: NC, United States
[quote=oliveoil]The bolts that hold the crank arm on are 14 or 15mm and are regular right threaded. But you need a "crank arm puller" to take the crank arms off. Then the Bottom bracket (BB) can be disassembled. You will need some bottom bracket tools also. Any bike shop can sell you these tools. The left side of the BB, the non drive side, as you are sitting on the bike looking down, is normal right hand drive and this is the only side that needs to be removed when overhauling the BB. Hope this helps. [/quote.
I do not agree that you only need to loosen the non-drive side. To properly clean out and re-grease the bottom bracket, you really need to remove both cups.
97 Camry M1 5W30 HM & OEM Filter
14 Camry TGMO 0W20 & OEM Filter
08 Volvo S60 M1 0w40 OEM Filter
#3443168 - 08/01/14 06:32 PM Re: Campy crank threads L. or R. thread? [Re: teddyboy]
oliveoil Offline
Loc: snow and sun
Not really. This is why we have dexterous fingers and opposable thumbs. One should always check the drive side cup for tightness.
#3443181 - 08/01/14 06:48 PM Re: Campy crank threads L. or R. thread? [Re: oliveoil]
dailydriver Offline
When I had these, I used to open up the drive side cup for a total cleaning every other repack. wink
M1-206 oil filter
#3444744 - 08/03/14 01:44 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
daves66nova Offline
Loc: los angeles
I ended up taking it to a good bike shop. They charged me 15.00 to completely take apart the cranks and everything else there and the headset. ON TO PAINT NOW!!
#3444929 - 08/03/14 05:53 PM Re: Campy crank threads L. or R. thread? [Re: daves66nova]
dailydriver Offline
That's not bad for all of that, especially in So-Cal. wink
M1-206 oil filter
