Originally Posted By: bullwinkle
I would add-watch for an F-Super Duty one as well, preferably 7.3 IDI & ZF 5 speed. I can squeeze 12-13 MPG out of mine if I baby it, & it's over 12,000 loaded. Can't see getting over 10 with a 454.
Since he would need 11 MPG to cover the added fuel cost of a diesel, selling his truck to get a small amount of MPG may not be very cost effective. The other problem is that he would have to know the condition of his truck versus that of someone's Ford IDI.
He mentioned the cost of head gaskets and new cylinder heads for diesels. Depending on which diesel you get, there are plenty of rebuilt heads out there, and they may not be too expensive. You mentioned that you can find aftermarket performance heads. Do you know what a new computer chip would cost, in order to function with the new heads? When dealing with diesels, you could port your existing heads, and not completely need to tune for the system changes. Old distributor pumps could often be adjusted by turning a few screws in order to compensate for design changes.
The price of diesel maintenance of a diesel is also a huge concern. How much would a rebuilt diesel distributor pump and injectors cost in the case he uses a Ford IDI engine? With the 454 TBI, an entirely rebuilt unit isn't nearly as bad, and also, there is far less labor to replace a TBI module versus a diesel distributor pump and injectors. If any one of those problems surfaces, the gain of a few MPG would take an extremely long time to recover from. It is my undertsnding, however, that glow plugs and control modules on non computerized diesels isn't all that much more expensive than having to replace all spark plugs and an ignition distributor.
Does a Ford IDI use a fuel pump in the fuel tank? Those pumps can get more expensive than the in-tank pump for a gasoline engine.
