Originally Posted By: y_p_w
Originally Posted By: IndyIan
Originally Posted By: edyvw
However, I would not consider this real winter tires, bcs if you look right side of the tire, it is actually summer tread pattern.
Yup. And they really have no incentive to make good all-season tires. They'd be killing their summer/winter tire market if they did come up with one.
I am sort of coming to the conclusion that the ice tires actually make a decent all season tire if you don't do a ton of miles. My local GM dealer found a set of new 2008 Xice in the back room, so for $200 all in I put them on the Tracker this spring. No unusual wear so far and they drive nice on the road, and are good for some mild off roading around our place. Probably by fall we'll have 6-7k miles on so I'll take some tread measurements when I rotate them and get some numbers.
All the siping makes them really squishy. It's really generally suited for one purpose. Not ideal if it's a performance car and there's dry road.
Yeah, the Tracker has 75 series tires with a recomended pressure of 26 psi, so its not a real corner carver
I suspect though, that something like an Xice does perform better than a set of low end all seasons in the summer and low end winter tires in the winter for some amount of miles. The summer performance would get better with wear, and of course the winter would get worse. I'll see how it works out.
