I did a full rebuild on the drums in our tundra last year, forced by leaky cylinders and pretty obnoxious squeal under mild braking. All new hardware, rebuilt cylinders, springs, etc. went in as well as new Wagner ThermoQuiet shoes.
I noticed immediately that the new shoes did not have the same stopping power as whatever came out. I have no idea what they were. They also had brake fluid in them, so I really didn't know what the old shoes felt like dry. With the new shoes, the E-brake was not nearly as strong as well-- maybe half as much holding power.
1 year later-- this has become a problem... I adjusted the Level Sensing Proportioning Valve (LSPV) to allow more rear brake action, however that thing has a mind of its own--- and over-adjustment quickly becomes inconsistent braking as it's just looking at bed height at time of application -- so bumps and vibrations play into it.
Current pedal feel-- is awesome. Smooth and firm during application. there is no air in the lines, anywhere. Brake booster holds vacuum and doesn't leak down with the engine off.
Since we tow, and we tow a lot, the fronts are getting beaten pretty bad, especially with the rear being less effective. They seem to have glazed on our last trip, as they smoked some and now have very little bite-- parts on order. I'm seriously considering a rear disc conversion with sequoia parts. It's a bit of coin, however, and I'd consider trying another shoe if anyone has some suggestions.
New shoes??? suggestions? or just bite it and swap to discs?
-M!
-M!
