killing weeds without poisoning well
by oilboy123
07/24/16 01:27 AM
1999 ford expedition factory mercon v synthetic??
by merconvvv
07/23/16 11:40 PM
Buick 3800 - "Von Voyage" oil change?
by Alex_V
07/23/16 10:41 PM
Low oil level light on, but level not THAT low....
by gregk24
07/23/16 10:26 PM
Is SuperLube syn multi grease universal
by NattyBoh
07/23/16 10:05 PM
How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
2016 Tacoma 3.5L V6 4x4
by NavyVet88
07/23/16 07:10 PM
Question on 05 Nissan tranny w/120k
by NattyBoh
07/23/16 06:58 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
34 registered (bvl, Boomer, Bandito440, andrewp1998, b1amgm47, 1foxracing, 5 invisible), 628 Guests and 6 Spiders online.
58578 Members
66 Forums
252174 Topics
Page 2 of 2 < 1 2
#3430713 - 07/20/14 09:46 PM Re: Running conventional in newer Euro cars [Re: KenO]
JHZR2 Offline
Loc: New Jersey
Modern specs have gotten more robust, this means synthetics too. But the oil temps seen in some vehicles means that a more oxidation-resistant lube is necessary. Grp III and III+ are likely more than good enough with the right chemistry add packs, but II+ and below likely aren't, so that would be my concern.
Time at temperature = oxidation and degradation.
Also, one would have to find the appropriate spec, such as ACEA A3, which is not easy to find in a typical viscosity conventional.
#3430719 - 07/20/14 09:49 PM Re: Running conventional in newer Euro cars [Re: KenO]
Lolvoguy Offline
Loc: Canada
I'm actually amazed that ALL the newer turbo econo and mid size cars haven't had more engine/turbo failures when running regular oil. I mean, regardless of the technology of these newer cars, they run much hotter and are under a lot of stress that their NA predecessors weren't. I'd be interested to see how they stand the test of time.
I remember in the early 80's with Saab and Volvo being the major users of turbo's on gasser engines, these turbo setups would usually last about 100k miles then a new turbo was in order, regardless of how much you maintained them.
07 Focus ZX4 SES- Wife
88 BMW 325is- Mistress
03 Suzuki SV650S- One night stand
#3430748 - 07/20/14 10:20 PM Re: Running conventional in newer Euro cars [Re: KenO]
redhorse554 Offline
Loc: so cal
how about the customer that buys one quart at a time until the red light goes out. never pulls the dip stick.
'97 ford f-150 4x4(lubro 5w40)
'02 yam road warrior(motul 15w50)
'04 bmw r1150rt(motul 15w50)
'10 bmw x5m(ultra 5w40)
'12 kia optma xs(ultra 5w40)
#3431431 - 07/21/14 05:29 PM Re: Running conventional in newer Euro cars [Re: KenO]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
There is no problem per se running a conventional motor oil if shorter oil change intervals are maintained but the motivation to use a dino is initial cost savings and no one is thinking it through that a shorter OCI may be required.
What is most likely is that those going cheap on using a Dino are more likely to not check the oil level and will delay having the oil changed as required.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3431761 - 07/21/14 10:44 PM Re: Running conventional in newer Euro cars [Re: KenO]
dparm Offline
Loc: Chicago, IL
Unless of course the motor was designed and engineered around synthetic oil, as Doug Hillary has alluded to...
2011 BMW M3 sedan ZCP
Page 2 of 2 < 1 2
