$1.33 for a GALLON of 87!
by Vern_in_IL
8 minutes 45 seconds ago
Eating out, beware you all
by CourierDriver
25 minutes 15 seconds ago
Best Sponge For Washing Cars
by George7941
30 minutes 5 seconds ago
Old school (ethanol) and (leaded) fuels
by mjoekingz28
Today at 05:37 PM
Opinions on this oil filter relocation setup
by bspag
Today at 04:42 PM
E-brake tightening on Cobalt Chevrolet
by mjoekingz28
Today at 04:32 PM
Mobil 1 EP rollbacks at local Walmart
by HTSS_TR
Today at 04:29 PM
GM worker Saves a life on company property.
by Charlie1935
Today at 03:43 PM
Idle wear
by DrRoughneck
Today at 03:27 PM
Download a WHOLE site? AllData, Toyota TIS etc
by SumpChump
Today at 03:07 PM
Mixing washer fluid with windex?
by 55Test
Today at 02:48 PM
Car won't start, no gas movement observed, pump?
by Hal9000
Today at 02:39 PM
Miningman, pocketdrummer, bspag, Lana, phem0r
56883 Registered Users
105 registered (barkingspider, akela, 901Memphis, Astro14, adamrc, Abakev, 12 invisible), 1549 Guests and 208 Spiders online.
56883 Members
66 Forums
244520 Topics
#3430429 - 07/20/14 05:43 PM J20D Hy-Gard Low Viscosity Oil Specs
SwedishRider Offline
Loc: not Sweden
Does anyone know the viscosity of J20D Hy-Gard Low Viscosity oil? Or maybe have a link to the complete specs of the oil. I have searched the interwebs and haven't been able to find it. Thanks.
#3430438 - 07/20/14 05:50 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
roadrunner1 Offline
Loc: oh
'15 F350 6.7
#3430445 - 07/20/14 05:56 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
roadrunner1 Offline
Loc: oh
Property
Units
ASTM
method
Hy-Gard
Hy-Gard
Low-Viscosity Hy-Gard
Viscosity
mm2/s (cSt)
D-445
40 degrees C
59
33
100 degrees C
9.4
7.1
Pour Point
degrees C
-40
-51
Flash point (min.)
degrees C
227
180
Total base no.
mg KOH/g
11
13
Viscosity index
140
195
'15 F350 6.7
#3430448 - 07/20/14 05:57 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
roadrunner1 Offline
Loc: oh
well for some reason it didn't paste as it was printed.
'15 F350 6.7
#3430456 - 07/20/14 06:01 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
Loc: not Sweden
That was quick! Thanks for the info and link.
That leads me to the other issue: other than that fluid itself, what could be used as a reasonable substitute? Would a 5W-50 or 20W-50 full synthetic be a reasonable replacement? If not, what would?
#3430467 - 07/20/14 06:17 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
Realtech214 Offline
Loc: Florida
Hy Gard is good stuff! I use it in my power steering in my chevys !
2015 Silverado Crew Cab 5.3 LT
2001 Suburban LT
- I NEVER THOUGHT I WOULD LIKE OIL SO MUCH -
#3430469 - 07/20/14 06:21 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
roadrunner1 Offline
Loc: oh
'15 F350 6.7
#3430477 - 07/20/14 06:34 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
MinamiKotaro Offline
Loc: TN
A 50wt oil is about twice as thick (or more) as low-vis hy-gard. The closest engine oil would be a 20wt. Dex/Merc or Type F atf would be a much better match than engine oil.
1967 VW Beetle: Mag1 5w40 All Fleet/Motorcraft FL400S
2004 Saturn Ion: Delo 5w40/Wix 57082XP
2014 Polaris Ranger 570: Delo 5-40/Wix 51356
#3430489 - 07/20/14 06:45 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: MinamiKotaro]
Loc: not Sweden
That's interesting. It's for a Tuff Torq K58 transaxle that someone in another forum was asking about. I am surprised as many, many TT models are spec'd for 5W-50.
#3430532 - 07/20/14 07:28 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
Rand Online   content
Loc: NE,Ohio
I believe jd low vis hygard replaces ATF type F if that helps any
no doubt the JD stuff is better.
its actually a really good product, would use it where spec'ed its not even terribly high priced.
Edited by Rand (07/20/14 07:28 PM)
2015 Forester I-Premium 6MT
#3430537 - 07/20/14 07:33 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: roadrunner1]
Loc: not Sweden
This link states that "Low-Viscosity Hy-Gard has an ISO 32 viscosity grade".
So wouldn't Amsoil Synthetic Multi-Viscosity Hydraulic Oil - ISO 32 be a substitute for it (though only sold in 5 gallon pails and up): http://www.amsoil.com/shop/by-product/hy.../?code=HVH05-EA
#3430541 - 07/20/14 07:36 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
Loc: not Sweden
Here's a link to that other discussion: http://www.mytractorforum.com/showthread.php?t=636921
#3430708 - 07/20/14 09:39 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
jhellwig Online   content
Loc: Ottumwa, Iowa
If a john Deere dealer is close by there is no need to substitute. It isn't any more expensive than any substitute you will find.
Engine oil is made for engines not transmissions.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2013 Chevy Traverse lt 3.6l direct injection
1983 Chevy K5 350
#3430731 - 07/20/14 10:02 PM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: jhellwig]
Loc: not Sweden
The OP in the other forum has already put his transaxle back together and refilled it with Castrol Syntec 5W-50.
I think the original intent of that thread was to find an alternative since the JD dealer was closed today (Sunday) and he wanted to get the job done quickly. I was just curious as to what could be substituted for that fluid... just pure curiousity. I don't own any JD equipment. smile
#3432187 - 07/22/14 11:33 AM Re: J20D Hy-Gard Low Viscosity Oil Specs [Re: SwedishRider]
mrsilv04 Offline
Loc: Illinois
My next door neighbor is the general manager of a John Deere Construction equipment dealership.
The last time that I changed out the Lo-Vis Hy-Gard fluid in my 425 AWS, I mentioned to him trying to find a substitute for it... he immediately responded with "Don't do it".
If there were some sort of an acceptable substitute out there that he knew of, I know that he'd tell me. I mentioned ISO 32, and he waved it off, and said it is not the same.
He told me that the Lo-Vis Hy-Gard is actually a semi-synthetic blend.
He had no financial interest in this, as I was only going to be buying 6 quarts, and the smallest amount that he could sell me would be a 5 gallon bucket.
I paid a little over $4 a quart for it at the JD Ag dealer. Considering that I pay the same amount of money for a quart of semi-synthetic Pennzoil for my truck, I'm not going to complain about what John Deere charges on this.
Of course, finding it on a Sunday is still going to be an issue... frown
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
