08 caravan / oil seeping from spark plug
by Mark72
02/12/16 11:25 PM
Holley Accelerator pump probem
by nwjones18
02/12/16 10:56 PM
Sealant for threaded air hose fittings.
by BigD1
02/12/16 10:37 PM
on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
Left my lights on and battery died.
by joegreen
02/12/16 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
02/12/16 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
02/12/16 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
02/12/16 06:54 PM
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
49 registered (anonobomber, 2015_PSD, AdRock, 01_celica_gt, 87sammy, 1345, 7 invisible), 704 Guests and 99 Spiders online.
56902 Members
66 Forums
244626 Topics
Page 1 of 2 1 2 >
#3430390 - 07/20/14 04:59 PM Cleaning a neglected system
Clubber_Lang Offline
Loc: SC
Is cleaning a neglected system a [censored] when it comes to causing leaks?
I just changed coolant on a very neglected 96 Ford f150. It was so bad i didnt flush the system, just drained and refilled to avoid leaks.
I'd like to get the system clean, how would you handle it? Frequent changes? Filling system
with distilled water and driving, draining and refilling? Flushing? Or just frequent changes? Or infrequent to not disturb the crud possibly sealing the system?
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Sir W.C.
#3430399 - 07/20/14 05:07 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
sciphi Offline
Loc: Upstate NY
Fill it with regular tap water, drive it a few days, then rinse and repeat until the water in there comes out clean. You're in coastal SC, so you won't have to worry about freezing for another 4-5 months yet.
2009 Honda Fit Sport
2012 Chevrolet Cruze Eco
#3430406 - 07/20/14 05:16 PM Re: Cleaning a neglected system [Re: sciphi]
Wolf359 Offline
Loc: MA
I wouldn't use regular tap water in any cooling system. Anti-freeze also prevents corrosion and also raises the boiling point of the system, water would be 212 and a 50/50 mix would be 223. Also when it's under pressure, it's another 45 degrees higher.
#3430418 - 07/20/14 05:32 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
Rolla07 Offline
Loc: MTL, CANADA
I would use distilled water in place of tap water or just do a bunch of drain and fills.
Edited by Rolla07 (07/20/14 05:33 PM)
2007 Corolla Red Pearl 134k miles
TGMO 0w20 & Toyota OEM filter
#3430423 - 07/20/14 05:36 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
Chris142 Online   content
Loc: apple valley, ca
If its that bad beg,borrow or steal a bazooka flush gun. I pull the block drains and bazooka the cooling system till it comes out clean.
Theres lots of rust stuck in the corners and lower edges of the block that cant be removed by just draining.Once your done with that you can run your distilled and coolant mix.
http://www.ebay.com/itm/OTC-Blast-Vac-Mu...ols&vxp=mtr
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3430432 - 07/20/14 05:46 PM Re: Cleaning a neglected system [Re: Chris142]
Loc: SC
That seems cool, but wouldnt you be concerned about leaks?
#3430433 - 07/20/14 05:46 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
901Memphis Offline
Loc: Northern Kentucky
Nothing wrong with straight water, the pressure in the system plus the waters boiling point is more than enough to cope with the heat. Plus the water holds more heat than Antifreeze so it should work better for short term while cleaning. I wouldn't be concerned with corrosion during a cleaning cycle.
2002 Buick Century 118k - Built 4T65e - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317
#3430437 - 07/20/14 05:49 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
fdcg27 Offline
Loc: OH
Not necessarily.
I've used flush products and a flushing tee on neglected cooling systems without problems. If you do flush, make sure that you have the heater on high if this instalation uses a heater control valve.
Look at it this way.
A flush doesn't create leaks. It only makes them readily apparent.
Would you rather discover and fix the leaks now, or would you prefer that they reveal themselves when you're far from home?
Go ahead and flush the cooling system.
It'll probably be fine and if it isn't, you can fix anything that needs fixing in the comfort of your own driveway.
Also, unless you know that the themostat had been changed recently, change it while you have the system drained.
It's usually worth it to spend a little more for the OEM part.
You might want to replace the pressure cap as well and have a good look at the various hoses.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3430444 - 07/20/14 05:54 PM Re: Cleaning a neglected system [Re: fdcg27]
Loc: SC
Changed radiator cap and t stat as part of large prev maint on the truck.
Originally Posted By: fdcg27
Not necessarily.
#3430472 - 07/20/14 06:26 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
fdcg27 Offline
Loc: OH
You've got two options, then.
Run a number of drain and fills with plain water until it comes out clean, or install a flushing tee, use a flush chemical and continue flowing water through the flushing tee until it comes out clean.
Citric acid is a good and safe cooling system cleaner.
Many dishwasher detergent booster are citric acid.
You can check labels and then use whatever's left in the dishwasher.
#3430490 - 07/20/14 06:45 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
MetalSlug Offline
Loc: vicksburg ms
drain the radiator, fill it up, run the car for 10-15 mil, cool down, drain again and fill it up with tap water is fine ( garden hose ), run for day or 2, let it drain over night, next morning fill it up with coolant. or repeat drain and fill many time you like. you be fine running straight water for few day,
Being home with my wife and kids is bless -MetalSlug-
#3430500 - 07/20/14 06:52 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
gathermewool Offline
Loc: New England
Getting creative may not be worth the risk or investment...
IMO, you've done more to lengthen the life of this truck by just changing the fluid. So long as you drained and refilled with a compatible fluid and you weren't overheating to begin with, the corrosion inhibitors you just added will be all this engine needs for now.
I tried being creative with an old Subie and ended up with a leaking coolant system when everything was fine before. I should have simply drained and refilled with Subie coolant (and Subie coolant conditioner) and called it good...
Edited by gathermewool (07/20/14 06:55 PM)
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#3430505 - 07/20/14 06:59 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
Donald Offline
Loc: Upstate NY
I would do a couple of drain & fills with G-05. If the truck experiencing any problems like overheating? That is when I might consider a flush chemical.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3430517 - 07/20/14 07:16 PM Re: Cleaning a neglected system [Re: Donald]
Loc: SC
No overheating, but prior to the drain the indicated temp would raise slightly in traffic---but this was 100 degree. Heat gridlock traffic were talking about.
Edited by Clubber_Lang (07/20/14 07:16 PM)
#3430520 - 07/20/14 07:17 PM Re: Cleaning a neglected system [Re: Clubber_Lang]
Loc: SC
Sorry, what is G05?
Page 1 of 2 1 2 >
