Wix coolant filter change and cut open
by A310
05/31/16 03:45 AM
O2 Sensor Voltage
by Falcon_LS
05/31/16 01:36 AM
Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
31 registered (bourne, chrisri, ActionJoe, BigD1, czbrian, car51, 6 invisible), 514 Guests and 316 Spiders online.
58031 Members
66 Forums
249618 Topics
#3430090 - 07/20/14 11:07 AM Do Bosch Distance+ Filters show tears?
Cristobal Offline
Loc: Cal-Neva-Ari
Do Bosch Distance+ Filters show tears? these specific filters.
This is my question. I am using one now and have another in my stash. If you know of any issues, please tell me.
I know they have been, or are, made by Purolator, but I do not want to hear anything about Purolator filters in general, because that does not give the information I want.
Surrounded by ferocious, snarling, & spoiled Poodles!
#3430123 - 07/20/14 11:48 AM Re: Do Bosch Distance+ Filters show tears? [Re: Cristobal]
99Saturn Offline
Loc: NY
Mine was fine after ~17K. Not much of a sample size though. I have another one on now, at 3K, but it will be a while before it comes off at 15K or 20K.
#3430124 - 07/20/14 11:50 AM Re: Do Bosch Distance+ Filters show tears? [Re: Cristobal]
Rand Offline
Loc: NE,Ohio
NO,
and the Purolator filter thing is reaching tin foil hat proportions.
Anything with a wire mesh backed filter media wont flex as much if that makes you lose sleep.
Edited by Rand (07/20/14 11:51 AM)
2015 Forester I-Premium 6MT
#3430125 - 07/20/14 11:51 AM Re: Do Bosch Distance+ Filters show tears? [Re: Cristobal]
abycat Offline
Loc: grande prairie AB
99saturn. are you doing 15k to 20k changes in your Saturn?
2004 f350 6.0
2011 nissan versa hb
#3430128 - 07/20/14 11:52 AM Re: Do Bosch Distance+ Filters show tears? [Re: abycat]
Rand Offline
Loc: NE,Ohio
if you look at his link
he left the same oil filter on for 3 oci's
#3430147 - 07/20/14 12:06 PM Re: Do Bosch Distance+ Filters show tears? [Re: Rand]
99Saturn Offline
Loc: NY
^ This. I usually stick to 5K intervals. From when I bought it at 120,000 through about 185,000/190,000 it got "whatever's cheap", lots of Peak, SuperTech and NextGen. At 190,000, in part b/c of the novelty of never using a synthetic before and in part b/c of getting synthetics for next to free/cheaper than conventionals I've used synthetic and some MMO.
Consumption has always been pretty steady at 1qt./500 miles - it might be a little less now, but I tend to also just throw in 1/4 quart every few of days as well, so my tracking might just not be as good.
I plan on leaving the D+ on for 3-4 changes, assuming the car is still running by then, I'll cut and post. If it's not, I'll just retreive the filtermag. wink
Edited by 99Saturn (07/20/14 12:10 PM)
#3430174 - 07/20/14 12:38 PM Re: Do Bosch Distance+ Filters show tears? [Re: Cristobal]
Rand Offline
Loc: NE,Ohio
they last a long time while burning oil. In most cases people not keeping the oil topped up is what kills them.
My cousin's friend had a 2000ish saturn with <1qt of oil in it.
We were cleaning out an apartment after a death in the family
I'm dumping 2qt in the cousin's windstar.. and her friend goes...
"my car was making funny noises can you check the oil."
took 3qt to hit the bottom of dipstick IIRC
fill was 4 or 4.5qt IIRC
For some reason it blew up 2months later when she never checked or added any oil....
If you just keep them full they go longer than you want them too.
Oh and my cousin thought the low oil pressure light was the low oil level light.. she would just dump in a quart or 2 when it started flickering crush
Edited by Rand (07/20/14 12:40 PM)
#3430225 - 07/20/14 01:15 PM Re: Do Bosch Distance+ Filters show tears? [Re: Rand]
Nick R Offline
Loc: Albany, NY
NO,
MMmmmmm, I don't think the D+ uses wire back media. I don't know of any filters that do other than the FRAM Ultra.
2013 Ford Focus SE 2.0L/70,000miles/Motorcraft Blend 5W-20/FL-910S
#3430235 - 07/20/14 01:30 PM Re: Do Bosch Distance+ Filters show tears? [Re: Rand]
ZeeOSix Offline
Loc: PNW
... and the Purolator filter thing is reaching tin foil hat proportions.
It's all a made up illusion. LOL
A filter's brand name doesn't matter ... what's inside does.
#3430237 - 07/20/14 01:33 PM Re: Do Bosch Distance+ Filters show tears? [Re: Nick R]
ZeeOSix Offline
Loc: PNW
Toyota TRD, Royal Purple and Purolator synthetic use wire backed media. I'm sure there are others also.
Link: Purolator Synthetic Cutaway
#3430280 - 07/20/14 02:33 PM Re: Do Bosch Distance+ Filters show tears? [Re: 99Saturn]
Cristobal Offline
Loc: Cal-Neva-Ari
If consumption is about 1 quart every 500 miles, unless you are doing a ton of VERY short trips, you might as well just buy the less expensive dinos or synthetics and just add a quart every 500 miles, use a long-life filter, and do not do an oil change until 15,000 miles.
#3430281 - 07/20/14 02:35 PM Re: Do Bosch Distance+ Filters show tears? [Re: Cristobal]
Cristobal Offline
Loc: Cal-Neva-Ari
My present D+ has been on for 3680 miles. I will change the oil at 7500 miles and will leave the filter in. Both oil and filter will be changed at 15,000 miles.
#3430441 - 07/20/14 05:51 PM Re: Do Bosch Distance+ Filters show tears? [Re: Cristobal]
99Saturn Offline
Loc: NY
The question I always find myself asking is if there is anything additional in suspension in the oil as a function of the burning that warrents dropping it earlier (5K) / could increase burning further given the ring problems on these engines. shrug
