Any experience with 98-02 corolla?
by barkingspider
8 minutes 13 seconds ago
nice video
by raaizin
42 minutes 42 seconds ago
Dumbest thing you have been told at a parts store
by tojo1968
48 minutes 39 seconds ago
Our cars are due for oil, any recommendations?
by MilesToEmpty
Today at 02:30 PM
roof shingles- come from oil?
by edwardh1
Today at 02:28 PM
2015 Honda Accord FF UOA 8350 miles
by dieselworld
Today at 02:09 PM
Mobil 1 has highest film strength
by DrRoughneck
Today at 01:10 PM
A guy at the gym.....
by Doog
Today at 12:26 PM
Fram xg3976a or wix 57620 for 5.9l cummins?
by monster1
Today at 11:52 AM
Fram XG2 vs Motorcraft 820s
by doolah02
Today at 10:57 AM
06 Elantra rough start up
by dan765
Today at 10:52 AM
Grand old ship...new life?
by andrewg
Today at 10:29 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
105 registered (2015_PSD, 2oldtommy, 97K15004WD, 05LGTLtd, 90crvtec, adelody, 11 invisible), 1719 Guests and 127 Spiders online.
56834 Members
66 Forums
244270 Topics
#3430284 - 07/20/14 02:38 PM GM Passkey III didn't require programing?
Falcon_LS Offline
Loc: Kuwait
So I lost the master key for my Envoy, so I got a new fob and coded key from the dealer. They asked me to come back tomorrow for programming, so I figured I'd do it myself.
I put the new uncoded key in the ignition and turned it on - five seconds later the security light went off. I cranked the engine and it fired right up! I tried the 2nd memory key and it fired right up. Am I missing something here?
99 Explorer EB: M1 0W40/FL1A
00 Pajero: M1 0W40/26300-35503
01 Marquis: M1 ESP 5W30/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: M1 ESP 5W30/M1-206
#3430325 - 07/20/14 03:25 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Trav Offline
Loc: MA, Mittelfranken.de
Try leaving the Master in the house and try it.
#3430331 - 07/20/14 03:39 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
eljefino Offline
Loc: ME
Maybe someone put in a remote starter and it has a bypass module you don't know about. Did you get it new?
#3430345 - 07/20/14 03:56 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
Trav - same thing. shrug
I bought it off the original owner who never changed/added anything.
Based on what I've read, it appears I have a Pass-Lock system, which to my understanding is different than Pass-Key. To my understanding, there is no chip in the key - which explains why it cost $10 for a Genuine GM key vs. $30 for my Ford PATS key - the key is just used to make contact between the tip and the base of the ignition cylinder. The resistor is apparently located in the ignition cylinder itself. Maybe that explains why.
#3430360 - 07/20/14 04:15 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
dishdude Offline
Loc: Phoenix
Passlock just checks to make sure there is a key in the cylinder, passkey III has a transponder chip in the head of the key and requires programming. Is there any marking on the blade of the key such as PK3 or a circle with a + in the center?
2015 Grand Cherokee 1k mi
2001 GMC Sonoma 207k mi
#3430370 - 07/20/14 04:26 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
No markings on the key.
#3430422 - 07/20/14 05:36 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
dishdude Offline
Loc: Phoenix
No marking on the key means it is a Passlock system, no programming necessary.
#3430606 - 07/20/14 08:34 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
itguy08 Online   content
Loc: Central PA
So what exactly is this system supposed to prevent? Hot wiring can still be done - just put any old key in there....
#3430672 - 07/20/14 09:13 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
George7941 Offline
Loc: Toronto, Canada
Hot wiring will not work on Passkey systems since there are Hall effect sensors in the ignition lock cylinder and the BCM must see the pattern generated when the ignition key is turned normally, else the BCM does not enable fuel.
2006 GMC Sierra 4.3l, NV3500,G80 locker rear, Formula Shell Synthetic 5W30, Wix 51036, Dexcool.
1987 BMW R80
Staying out of the right lane a lot.
#3430838 - 07/21/14 06:15 AM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
eljefino Offline
Loc: ME
^ yup that.
Deliberately confusing terminology on GMs part. But, they still get credit for putting passlock on the cheaper cars-- it still deters theft.
#3430862 - 07/21/14 07:04 AM Re: GM Passkey III didn't require programing? [Re: George7941]
Loc: Central PA
That makes better sense. Thanks.
