'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
2 minutes 27 seconds ago
What is the purpose of a 4.4 litre oil container?
by vitez
11 minutes 58 seconds ago
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
30 minutes 2 seconds ago
Briggs and stratton flathead?
by pdxglocker9mm
41 minutes 14 seconds ago
Charcoal
by dlundblad
Today at 09:43 PM
2013 Dodge Dart: replace AF on miles or time?
by vitez
Today at 09:20 PM
Rotella T5 10w30 or QSUD 5w30
by GumbyJarvis
Today at 09:04 PM
People running thru red lights. You ever follow th
by motor_oil_madman
Today at 08:30 PM
747-400 versus 747-8
by mjoekingz28
Today at 08:22 PM
14psi bypass pressure for small engines?
by motor_oil_madman
Today at 07:47 PM
'13 Wrangler 2.5" lift
by JXW
Today at 07:37 PM
group 7 v6128 ford 6.7 7k miles
by robo339
Today at 07:34 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
76 registered (bdcardinal, 2015_PSD, barkingspider, 901Memphis, aquariuscsm, 9 invisible), 1232 Guests and 100 Spiders online.
57779 Members
66 Forums
248434 Topics
Page 2 of 2 < 1 2
#3394783 - 06/11/14 12:06 PM Re: Valvoline VR1 Racing Synthetic [Re: Darren270]
BillyTheKid Offline
Loc: ny
Sell the oil to me rather than use it LOL
#3395621 - 06/12/14 12:16 PM Re: Valvoline VR1 Racing Synthetic [Re: Darren270]
A_Harman Offline
Loc: Michigan
VR1 synthetic has no more zddp than other oils on the Porsche approved list, so it won't destroy your cats. But you should only run an oil that Porsche approves for that engine. Does a Cayenne require the A40 approval for oil?
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3398086 - 06/15/14 10:35 AM Re: Valvoline VR1 Racing Synthetic [Re: Garak]
gtmaster303 Offline
Loc: NJ, USA
Originally Posted By: Garak
Originally Posted By: gtmaster303
I called Valvoline and asked them if I can use it in my Cayenne and they said no. It will destroy the catalytic converters. Is this true?
One fill of VR1 isn't going to destroy anyone's cats, no matter how much oil the thing burns. I'd avoid it for the Cayenne because it's not an approved lube or even a reasonable facsimile thereof.
What do you mean by not a reasonable facsimile? I know it's not an approved oil but you're telling me it's not suitable to run for 10k like the Mobil 1 I've been running? It's a full synthetic race oil, so if anything I thought it would be better...
2002 Mercedes-Benz ML320
2010 Porsche Cayenne 3.6
#3398302 - 06/15/14 05:04 PM Re: Valvoline VR1 Racing Synthetic [Re: gtmaster303]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
Well, there are a few issues. I wouldn't worry about the phosphorous levels, really. What's the HTHS of this oil? I bet it's not 3.5 or above, as specified. That's the real issue that I was getting at - certain HDEOs would be a more "reasonable facsimile" of an approved lube than VR1. VR1's TBN is sufficient for moderate OCIs, but it's not an extended drain lube like the approved lubes are. Personally, from the list of your vehicle, if I were to use the VR1, I'd try it in the Jaguar.
Be careful of dedicated racing oils. VR1 is a bit different, but there are some with very low TBNs that aren't suitable for long OCIs, and some of them have ZDDP levels that are way too high.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3398385 - 06/15/14 07:19 PM Re: Valvoline VR1 Racing Synthetic [Re: Garak]
dailydriver Offline
Loc: Bucks County, Pa.
VR1 is a bit different, but there are some with very low TBNs that aren't suitable for long OCIs.
Yes.
Case in point; the Motul 300V Nismo 0W-30 states right in the PDS that it is only good for ~1700 mile OCIs. For an almost $40.00/liter oil! YIKES!!! crzy
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3410424 - 06/29/14 09:54 PM Re: Valvoline VR1 Racing Synthetic [Re: A_Harman]
gtmaster303 Offline
Loc: NJ, USA
If that's the approval rating, yes. I don't know off the top what its called exactly, but that sounds familiar from when I was reading through my manual
#3410426 - 06/29/14 09:57 PM Re: Valvoline VR1 Racing Synthetic [Re: Garak]
gtmaster303 Offline
Loc: NJ, USA
How long could I run it for then? Some users have used it for 5k with no problems, but even most conventional oils will last that long lol...
One bitog user posted he was going to use it for 10k. Trying to get in touch with him actually...
Edited by gtmaster303 (06/29/14 09:59 PM)
#3410578 - 06/30/14 06:15 AM Re: Valvoline VR1 Racing Synthetic [Re: gtmaster303]
I'd want to run a UOA if I were running something that out of spec. You don't want it shearing down too much, and you want to see how the TBN holds up. Given the sump capacity, 5000 miles might be a good starting point; I'd just hope the vehicle doesn't shear the oil too much.
#3430371 - 07/20/14 04:27 PM Re: Valvoline VR1 Racing Synthetic [Re: Garak]
gtmaster303 Offline
Loc: NJ, USA
The TBN is almost the same to Mobil 1 (factory recommended). The additives vary somewhat, but overall the whole pack is far greater than Mobil 1
VR1 has no boron or magnesium vs M1, but a LOT more calcium, zinc, phos, moly and sodium
I don't have any idea what these mean.
http://speedtalk.com/forum/viewtopic.php?f=1&t=28365
It's the only case I have so a UOA is not possible. Thoughts?
I'm thinking I might just use the quarts as top up if it's that outside the realm of approved oils.
#3430421 - 07/20/14 05:36 PM Re: Valvoline VR1 Racing Synthetic [Re: gtmaster303]
The HTHS might be a bit of a concern. Personally, I'd just run the stuff in the Jag, for which it's a far better fit.
I wouldn't call the additive package "better" than M1. It's different. If it were "better" than Mobil would simply copy VR1's additive package. It's not like they don't have the resources to do so. wink
#3430506 - 07/20/14 07:01 PM Re: Valvoline VR1 Racing Synthetic [Re: Garak]
gtmaster303 Offline
Loc: NJ, USA
Thing is the Jag may be gone before the next change frown hence why I was asking...
Edited by gtmaster303 (07/20/14 07:01 PM)
#3430614 - 07/20/14 08:41 PM Re: Valvoline VR1 Racing Synthetic [Re: Darren270]
Clubber_Lang Offline
Loc: SC
Im thinking about running it in my 4.9 f150 flat tappet engine, which was made for zinc. If i can find it on sale.
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Sir W.C.
#3430618 - 07/20/14 08:46 PM Re: Valvoline VR1 Racing Synthetic [Re: gtmaster303]
The real concern I'd have is about warranty. The Porsche spec isn't met, since it's a bit thin. You already know not to reign in the OCI a bit with the stuff. I don't doubt it would work, but it's not like it's a thousand dollars worth of oil that you have no choice but to use up in something.
Page 2 of 2 < 1 2
