Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
47 registered (09_GXP, 2015_PSD, AnthemBassMan, Al, 97f150, 5 invisible), 1043 Guests and 11 Spiders online.
58632 Members
66 Forums
252385 Topics
#3430365 - 07/20/14 04:20 PM Strange rear end leak
1kickbuttranger Offline
Loc: California
Well, I now have a strange rear end leak. A month ago when I dropped the transmission, as I pulled the driveline, I got a few tablespoons of gear oil drip out of the front of the yoke. I also noticed the yoke bolts were damp. The main seal is dry.
It's not leaking from the outer seal. The only thing I can compare it to is like when you install a harmonic balancer and don't use sealer on the keyway slot, and you get an internal leak from the bolt rather than the outer seal.
Well, it looks like it has gotten worse and oil has slung onto the exhaust pipe and under the truck. (Gotta love that gear oil smell)
I removed the driveline again this morning, and more fluid spilled out. I stopped by oreillys and picked up some rear diff permatex, and smeared some in between the flange and flange nut and then worked an o-ring in there. Pressed in there pretty good and let it cure for a coupe of hours. I'll see if that stops the leak.
Anyone ever had a similar leak?? Does the diff need to be looked at by a pro?
What seals the innards form leaking?
2002 Ranger XLT 3.0 5sp
1990 Mustang GT 5.0 5sp
#3430368 - 07/20/14 04:24 PM Re: Strange rear end leak [Re: 1kickbuttranger]
JTK Offline
Loc: Buffalo, NY
Could the vent be plugged and it's building pressure, forcing gear oil out?
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#3430535 - 07/20/14 07:31 PM Re: Strange rear end leak [Re: 1kickbuttranger]
Rand Offline
Loc: NE,Ohio
plugged vent? pinion seal?
I went through 2 pinion seals in 75000 miles on my 2002 4.0 4x4 ranger
although when they went they mostly just seeped and dripped off the diff.
Edited by Rand (07/20/14 07:32 PM)
2015 Forester I-Premium 6MT
#3430587 - 07/20/14 08:12 PM Re: Strange rear end leak [Re: 1kickbuttranger]
CurtisB Offline
Loc: Edmonton, Alberta, Canada
By "main seal" or "inner seal" you must be talking about the pinion seal. The pinion seal is the only oil seal in the pinion shaft/gear housing of a rear end, and it is merely pressed into the mouth of the pinion shaft/gear housing. A pinion seal is composed of both metal and rubber. The perimeter edge of the pinion seal which is pressed into and contacts the mouth of the pinion shaft housing is metal with a rubber seal adhered around the perimeter edge. The pinion seal also has a mouth, composed of rubber. The pinion flange or yoke (some rear ends have a flange and some have a yoke) has a sleeve that contacts and rides along the mouth of the pinion seal.
Here is a picture of a pinion flange and pinion seal: (the grey plastic thing around the perimeter of the pinion flange sleeve is the dust cap and is pressed in.)
Here is how they go together:
This is the first time I have ever heard of a pinion oil leak through the splines of a pinion yoke/pinion shaft and around the pinion nut. These things are on tight! And require a puller to remove. The reason there is no oil seal required in the first place is because the splines on the pinion yoke and that on the pinion shaft mate together so tight that it is not required. Are you sure this is not just a simple pinion seal leak? If it did not leak before why would it leak now? As there is no movement between the splines of a pinion yoke/pinion shaft and there should be no wear?
Either way, if you remove that pinion nut make sure you mark both the nut and pinion shaft together with a punch or permanent marker. If you decide to remove the pinion yoke you will also have to count and measure the exposed threads on the pinion shaft, that yoke must go back into exactly the same position as before or you will ruin your backlash setting.
2008 F150 XL 4.6L 2WD - FL820s, M1 AFE 0w20
2013 F150 STX 5.0L 4WD - FL500S, M1 5w20
#3430610 - 07/20/14 08:39 PM Re: Strange rear end leak [Re: 1kickbuttranger]
Loc: California
Like I said its a weird one. So the only thing sealing the front yoke to the pinion is a tight fit?
Here it is after I worked on it a bit, but you can see the main seal is dry, and the oil is either coming from the hole near the u-joint or simply between the two mating flanges.
I would say the diff was about a cup low.
#3430615 - 07/20/14 08:43 PM Re: Strange rear end leak [Re: JTK]
Loc: California
Not sure, I went out to take a look at it. It is just a hose that plugs into one of the axle tubes and runs to the frame up high with the other end open. no dirt or anything up there.
#3430635 - 07/20/14 08:57 PM Re: Strange rear end leak [Re: 1kickbuttranger]
clinebarger Offline
Loc: Fort Worth, Texas
Gear Oil can & will leak through the yolk splines.
2001 Chevy Camaro 5.3L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3430644 - 07/20/14 09:02 PM Re: Strange rear end leak [Re: 1kickbuttranger]
CurtisB Offline
You're right that is bizarre, and it doesn't appear to be leaking from the pinion seal. The only thing I can think of is the pinion nut may have loosened off due to vibration, and the pinion flange with it. If the pinion flange is loose riding on the pinion shaft that may be the source of that strange oil leak.
Here is a link to a DIY pinion seal replacement on an F150, you can see for yourself how everything fits together: http://www.f150online.com/forums/2004-2008-f-150/474995-how-replace-pinion-seal-2004-2008-a.html
#3430645 - 07/20/14 09:02 PM Re: Strange rear end leak [Re: 1kickbuttranger]
Rand Offline
Loc: NE,Ohio
wash it real good and see where it first reappears at?
#3430695 - 07/20/14 09:26 PM Re: Strange rear end leak [Re: clinebarger]
Loc: California
Any fix for this?
#3430778 - 07/20/14 11:18 PM Re: Strange rear end leak [Re: 1kickbuttranger]
wirelessF Offline
Loc: Oahu, Hawaii
For GM's they say to use RTV on the yolk splines but I haven't done that to my yota and silverado but yours is a special case so I might try RTV'ing the splines.
