PP Euro 5w40, 2014 VW Jetta 1.8T, 8250 mi.
by ryanm8
07/01/16 06:49 PM
Don't be blowing yourself up this holiday weekend
by skyactiv
07/01/16 06:40 PM
Finally
by bigdreama
07/01/16 06:24 PM
Happy Canada Day !!
by Papa Bear
07/01/16 06:12 PM
Napa July 2016 Sale - Platinum filters $7.50
by slacktide_bitog
07/01/16 06:11 PM
Menzerna Became "Jescar?"
by dkryan
07/01/16 05:32 PM
In the corn belt, non ethanol fuel is everywhere
by another Todd
07/01/16 05:13 PM
Cummins: Standpipe in fuel filter needed or not?
by Extreme-Duty
07/01/16 03:36 PM
Napa Canada, Magnatec, Delvac, Napa 15W-40
by Farmer
07/01/16 02:33 PM
Meijer 4 day sale (4th of july weekend)
by Kwuality
07/01/16 02:14 PM
Brakes for 2012 Subaru Legacy
by Picky1
07/01/16 01:56 PM
Microgreen Oil Filter 50% Off Discount Code
by kohnen
07/01/16 01:51 PM
Jennyp, dcdodge, igolfat8, makomike, Alexas
58338 Registered Users
91 registered (Berny, aprilia1, 01rangerxl, barkingspider, aquariuscsm, akcooper9, 8 invisible), 1762 Guests and 9 Spiders online.
58338 Members
66 Forums
251111 Topics
#3430284 - 07/20/14 02:38 PM GM Passkey III didn't require programing?
Falcon_LS Offline
Loc: Kuwait
So I lost the master key for my Envoy, so I got a new fob and coded key from the dealer. They asked me to come back tomorrow for programming, so I figured I'd do it myself.
I put the new uncoded key in the ignition and turned it on - five seconds later the security light went off. I cranked the engine and it fired right up! I tried the 2nd memory key and it fired right up. Am I missing something here?
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#3430325 - 07/20/14 03:25 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Trav Offline
Loc: MA, Mittelfranken.de
Try leaving the Master in the house and try it.
#3430331 - 07/20/14 03:39 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
eljefino Online   content
Loc: ME
Maybe someone put in a remote starter and it has a bypass module you don't know about. Did you get it new?
#3430345 - 07/20/14 03:56 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
Trav - same thing. shrug
I bought it off the original owner who never changed/added anything.
Based on what I've read, it appears I have a Pass-Lock system, which to my understanding is different than Pass-Key. To my understanding, there is no chip in the key - which explains why it cost $10 for a Genuine GM key vs. $30 for my Ford PATS key - the key is just used to make contact between the tip and the base of the ignition cylinder. The resistor is apparently located in the ignition cylinder itself. Maybe that explains why.
#3430360 - 07/20/14 04:15 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
dishdude Offline
Loc: Phoenix
Passlock just checks to make sure there is a key in the cylinder, passkey III has a transponder chip in the head of the key and requires programming. Is there any marking on the blade of the key such as PK3 or a circle with a + in the center?
#3430370 - 07/20/14 04:26 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Falcon_LS Offline
Loc: Kuwait
No markings on the key.
#3430422 - 07/20/14 05:36 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
dishdude Offline
Loc: Phoenix
No marking on the key means it is a Passlock system, no programming necessary.
#3430606 - 07/20/14 08:34 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
itguy08 Offline
Loc: Somewhere
So what exactly is this system supposed to prevent? Hot wiring can still be done - just put any old key in there....
#3430672 - 07/20/14 09:13 PM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
George7941 Offline
Loc: Toronto, Canada
Hot wiring will not work on Passkey systems since there are Hall effect sensors in the ignition lock cylinder and the BCM must see the pattern generated when the ignition key is turned normally, else the BCM does not enable fuel.
2006 GMC Sierra 4.3l, NV3500,G80 , Formula Shell Synthetic 5W30,Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
#3430838 - 07/21/14 06:15 AM Re: GM Passkey III didn't require programing? [Re: Falcon_LS]
Loc: ME
^ yup that.
Deliberately confusing terminology on GMs part. But, they still get credit for putting passlock on the cheaper cars-- it still deters theft.
#3430862 - 07/21/14 07:04 AM Re: GM Passkey III didn't require programing? [Re: George7941]
itguy08 Offline
Loc: Somewhere
That makes better sense. Thanks.
