Hi all,
My 2000 f250 4x4 V10 5spd manual with LSD and 63k mi has an intermitant but very strong vibration like a shuddering, growling, rumbling in 2WD. The 1st time it only lasted about 1 second. It had been making a swooshing noise that sounded like front left wheel bearing for several thousand miles before this, so i replaced bearing assembly even though it turned smoothly. After that, It still made the exact same swooshing noise and after a couple miles at 45mph, it had the strong vibration/shudder that lasted about 3 seconds. I stopped and locked the hubs manually. The vibration happened again in a couple miles, so seems like it's not the needle bearings in front stub shafts or locking hubs. On that last occurence, the vibe went on for 5 seconds, felt the same with clutch in, and went away only after truck slowed down to nearly a stop. I've driven it about 6 mi total since the 1st occurance.
Front right Wheel bearings feel smooth. I unbolted the driveshaft support bearing and it spins smoothly. The front u-joint maybe had a tiny bit of play, all bolts tight. I didn't check the nuts for yokes, but it didn't look like yokes had any play. Drive shaft slip joint moves smoothly. No up-down play at pinion shaft input into rear diff and output from transfer case. Rear diff oil was full with a little bit of silvery sludge on the magnetic filler plug, maybe 1/10 of a cc, no metals slivers or chunks. I raised the rear wheels and ran 5th gear 2WD at idle (~30mph) and touched a 4' listening stick to the drivetrain components. The only odd sounds were from the rear differential. It sounded like a bad bearing with random crunches and thuds mixed in with the normal whirring. Crunches and thuds were loudest at front of diff housing. I blocked one wheel and repeated in 3rd gear. You could hear noise like gears meshing (noisey spider gears? maybe was LSD clutches?). The differential was warm after 5-10 minutes, with the hotest area being about 3" from the front of diff, just before the housing widens.
So, i suspect the pinion bearing is bad and the intermittant shudder is the bearing race spining in the case when bearing siezes. Any other potential causes to check before i take it to a shop? Can anybody recommend a repair shop around Beaverton or Hillsboro Oregon? Need a quick fix as we are moving to a new house.
thanks,alex
thanks,alex
