A couple of quick questions about Amsoil Gasoline Stabilizer (http://www.amsoil.com/shop/by-product/fuel-additives/gasoline/gasoline-stabilizer/?code=ASTCN-EA):
1) Does the 16oz bottle have measuring lines or some easy way to measure out the correct fluid dose when treating gasoline for storage? Or will I have to use a measuring device of my own for every use?
2) What is the storage time frame when using Amsoil's Gasoline Stabilizer with 10% ethanol-based gasoline?
3) Is there any real advantage to using 89 or 93 octane gasoline in OPE, including tractors, string trimmers, etc.? What is the general consensus about higher octane gasoline?
