Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
Today at 09:11 PM
Which oil?
by SEMI_287
Today at 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
Today at 08:56 PM
Upgrading brakes
by ram_man
Today at 08:49 PM
Rear end sounds like an airplane
by mclasser
Today at 07:49 PM
GDI engine's and motor oils
by gabriel9766
Today at 07:42 PM
Old toyota Need shocks?
by ceast
Today at 07:27 PM
How to do a clean install
by Oldmoparguy1
Today at 07:21 PM
Troy Bilt Pony
by OSUFan86
Today at 06:43 PM
$1.33 for a GALLON of 87!
by Vern_in_IL
Today at 06:30 PM
Eating out, beware you all
by CourierDriver
Today at 06:13 PM
Best Sponge For Washing Cars
by George7941
Today at 06:08 PM
threeeightteen, TOADchunks, Longo9596, Roadrunner77z, rp5677
56888 Registered Users
94 registered (AZjeff, 69GTX, bdcardinal, 901Memphis, 74DartSport, 2015_PSD, 5 invisible), 1243 Guests and 214 Spiders online.
56888 Members
66 Forums
244530 Topics
Page 2 of 2 < 1 2
#3418217 - 07/08/14 12:52 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
Of course hoses have been checked and so on. I am going to change the coolant though. I think its overdue.
#3418255 - 07/08/14 01:20 PM Re: 95+ degree travel [Re: opus]
440Magnum Offline
Loc: Texas
A 30-weight (5w30, 10w30) is adequate for a smallblock Chevy in any ambient temperature, providing everything is in good shape and it isn't needing to "band-aid" a problem like worn bearings or a weak oil pump. 10w40 is already overkill, no need for anything else. Especially Lucas Mucus, which can lead to foaming problems.
When operating in high ambient temnps (and 95-100 isn't what I'd consider "high" at all) its most important to focus on the cooling system- belts, hoses, radiator clean (both air and coolant passages), coolant condition, radiator cap, fan(s), and overflow tank, etc.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3418297 - 07/08/14 01:44 PM Re: 95+ degree travel [Re: opus]
chrisri Offline
Loc: Fiume,Croatia,EU
Check your battery.If it's old it could let you down in that heat.
99 FIAT Punto Sporting 16v ( Shell Helix Ultra 5w40 )
06 FIAT Stilo MW 1.9 Multijet (Selenia WR 5w40)
93 Ford Escort 1.3 HCS ( Urania FE-LS 5w30 )
#3418357 - 07/08/14 02:25 PM Re: 95+ degree travel [Re: opus]
Vikas Offline
Loc: NorthEast
Does Lucas make anything for the cooling system? If yes, add it. That way you will *feel* comfortable.
#3418394 - 07/08/14 02:56 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
LOL, all is good. Just changing the coolant now and I'll call it good.
[Mental note; next time remove thermostat to speed process].
#3418407 - 07/08/14 03:06 PM Re: 95+ degree travel [Re: opus]
Turk Offline
Loc: MN
If it's overdue, yes, change it. thumbsup
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3418554 - 07/08/14 05:30 PM Re: 95+ degree travel [Re: opus]
Vikas Offline
Loc: NorthEast
And make sure you bleed the system properly otherwise you will have more problems than if you leave the coolant alone.
#3418623 - 07/08/14 06:24 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
We'd always park back end in a ditch and raise the engine to get the air bubbles out. smile
#3418845 - 07/08/14 08:57 PM Re: 95+ degree travel [Re: opus]
Oil_Flunky Offline
Loc: Michigan
Any weak tires like to blow out when it gets real hot. Make sure the spare is inflated, and your jack is serviceable with all the parts there.
Oil, you need it. Oil snobbery, you don't need it.
#3418915 - 07/08/14 09:40 PM Re: 95+ degree travel [Re: opus]
gman2304 Offline
Loc: n.c.
We all sound like mother hens....just go...and be safe, don't speed, take plenty of clean underwear, send us a post card, and let us know how your oil performed when you get back. geez!
#3418922 - 07/08/14 09:48 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
No kidding geeeee....
Its all good. For all anyone knows I'm a 20 year old kid thats never turned a wrench. I dont even remember being 20! Just wanted everyones take on it.
#3419137 - 07/09/14 03:34 AM Re: 95+ degree travel [Re: opus]
Turk Offline
Loc: MN
Well, at least change the Coolant, "as you said it's overdue"....
That makes sense. Unless people don't make sense anymore...
#3427046 - 07/16/14 10:41 PM Re: 95+ degree travel [Re: Oil Changer]
another Todd Offline
Loc: Southern CA
Originally Posted By: Oil Changer
You will be fine with the 10W-40. If you're itchin' to change the oil before the trip, your choices are almost limitless. SAE 30 or 40, an HDEO 10W-30 like Rotella T5 or Delo. 5 or 15W40 HDEO, an HM 10W30 or 40...like I said, endless. Skip the Lucas. That's what I think.
If you are worried I would suggest the HDEO 15-40. Delo 400LE is less than 12 bucks a gallon at Walmart's around here and it is a very robust oil, as are the other HDEO oils.
2015 Ford F250 Diesel Crew Cab FX4
(2)2005 Ford Focus ZX4, and ZX5
2005 Ford Escape
2006 Ford Escape
Page 2 of 2 < 1 2
