Originally Posted By: TiredTrucker
The multi fuel deuces I was around in the Army in the early 70's were generally AM General or Osh Kosh engines. Sure there were probably other varieties as well.
Some will dump a little K1 in the tanks of commercial trucks in extreme cold if they cannot get some D1, all while also throwing in some anti-gel. Thins out the mix a little to prevent fuel gelling. Problem is, it is not very cost effective as K1 and D1 are less efficient fuels in a heavy commercial truck. And it is a pretty dry fuel.
A diesel will run on kerosene. They'll run on jet fuel, in fact! Caterpillar actually had instructions for doing so.
While the TRUCKS were AM General, Kaiser, or Oshkosh, I recall they bought the engines from White and/or Continental.
