Getting hurt at work
by ram_man
08/28/16 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
43 registered (car51, 2002 Maxima SE, Atesz792, Boomer, Bandito440, 97f150, 6 invisible), 924 Guests and 31 Spiders online.
58943 Members
66 Forums
253658 Topics
Page 1 of 2 1 2 >
#3425794 - 07/15/14 06:33 PM Duke engine......better design?
mcrn Offline
Loc: FL
http://sploid.gizmodo.com/this-is-the-we...dium=socialflow
I searched and could not see that this had been previously posted.
#3425852 - 07/15/14 07:22 PM Re: Duke engine......better design? [Re: mcrn]
sicko Offline
Loc: Virginia
That first image is seriously cool to look at.
#3425867 - 07/15/14 07:36 PM Re: Duke engine......better design? [Re: mcrn]
webfors Offline
Loc: Great White North.. eh
Awesome! I would love to see this engine in production.
15 Civic, AFE 0w20, FU OF
13 Dodge GC, VWB 5w20, Purolator OF
13 SFV650, T6 5w40, OEM OF
07 VS800, OEM 10w40, K&N OF
Small engines; RT5 10w30
#3425910 - 07/15/14 08:14 PM Re: Duke engine......better design? [Re: mcrn]
gregk24 Offline
Loc: FL, USA
Wow, looks pretty cool. Not sure how reliable things would be though. Looks like it could have sealing issues.
2012 Honda Accord EX-L
Taffeta White - Ivory
40,xxx miles
PPPP 0w20 / Fram Ultra
#3425914 - 07/15/14 08:18 PM Re: Duke engine......better design? [Re: mcrn]
Quest Offline
Loc: beaver land EH?
mechanical complexity, coupled with sealing problems (just like wenkel engines), will plague this design in production mode.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3425916 - 07/15/14 08:24 PM Re: Duke engine......better design? [Re: gregk24]
Nick1994 Offline
Loc: Phoenix, AZ
That's what I thought. After many years of use, things are gonna start losing their pressure, metal will fatigue and the whole engine will need replaced. Interesting concept though.
2000 Toyota Camry 2.2L 216k
Mobil 1 EP 10w30 & Fram Ultra
#3425949 - 07/15/14 08:46 PM Re: Duke engine......better design? [Re: mcrn]
Win Offline
Loc: Arkansas
Looks like a wobble plate type of air conditioning compressor.
With spark plugs.
09 Torrent 3.6 V6 M1 0/30
09 Solstice 2.4 I4 Fram 5/30
08 G8 3.6 V6 Fram 5/30
04 Xj8 4.2 V8 Hav 5/40
99 S-10 2.2 I4 RECOVERED
94 Xj12 6.0 V12
#3425950 - 07/15/14 08:47 PM Re: Duke engine......better design? [Re: mcrn]
Chris142 Offline
Loc: apple valley, ca
very similar to many a\c compressors
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3425952 - 07/15/14 08:50 PM Re: Duke engine......better design? [Re: mcrn]
Subdued Offline
Loc: Youngstown, NY
that's a technological terror if I've ever seen one
2008 Chrysler Town & Country Touring 119k
2007 Toyota Yaris S 135k
2001 Toyota Corolla LE 159k
2001 Toyota Corolla CE 128k
#3425979 - 07/15/14 09:11 PM Re: Duke engine......better design? [Re: Chris142]
scurvy Offline
Loc: Chicago IL USA
Quite right. Same design as many existing AC compressors, which work beautifully. No reason it couldn't be adapted to work with spark or compression ignition.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#3426249 - 07/16/14 07:38 AM Re: Duke engine......better design? [Re: Win]
Trav Offline
Loc: MA, Mittelfranken.de
With spark plugs.
Just did a Sanden and it looked just like this 7cyl.
#3426363 - 07/16/14 10:32 AM Re: Duke engine......better design? [Re: mcrn]
morris Offline
Loc: ks, wichita
just count the weight of the moving parts. that will tell you all you need to know.
#3427006 - 07/16/14 09:39 PM Re: Duke engine......better design? [Re: mcrn]
Ram01 Offline
Loc: New York Queens
Wonder what weight oil that motor takes
#3427035 - 07/16/14 10:24 PM Re: Duke engine......better design? [Re: mcrn]
Kiwi_ME Offline
Loc: New Zealand
I should be patriotic but I think it's a nightmare too. Oddly the animated GIF shows the block stationary while the video shows it rotating, as it needs to, to move pistons past the ports and spark plugs. Perhaps the crank turns at twice head speed for a 4-stroke cycle.
Sealing the head under combustion pressure along with the complex machining of the wobble plate and con rods make it unattractive to me. And the touted advantages of balance and part count answer questions nobody has actually asked.
Compressors use this type of idea (wobble plate with a large number of small cylinders) to avoid pressure pulses in the input/output, hardly an issue in an IC engine where small cylinders have the disadvantage of high heat loss.
#3427134 - 07/17/14 04:09 AM Re: Duke engine......better design? [Re: mcrn]
bruno Offline
Loc: new Jersey
Back in the '50s this was tried .... it was called a Swash Plate design . Fine for clean conditions like AC compressors but otherwise it was a dud .
Just because it can be done doesn't mean it's worth doing .
Edited by bruno (07/17/14 04:11 AM)
Page 1 of 2 1 2 >
