Does Anyone Remember...
by pscholte
08/30/16 10:21 PM
Oil filter for fuel filter?
by leroyd92
08/30/16 10:19 PM
YouTube search geniuses help me out!
by Vern_in_IL
08/30/16 10:00 PM
BMW i8 Could Have 750 HP All-Electric After 2020
by HTSS_TR
08/30/16 09:48 PM
1991 Audi 200 Turbo Automatic Oil Standard?
by Logos
08/30/16 09:43 PM
Chevron & Sunoco & Speedway $100 Gift card $92
by gojoneeded
08/30/16 08:41 PM
Santa's Not Going To Be Happy
by Warstud
08/30/16 08:29 PM
can someone explain the Ecoboost to me?
by columnshift
08/30/16 07:50 PM
4 dragging weak brakes (after parked for a year)
by columnshift
08/30/16 07:34 PM
New S&W Shield 9
by funflyer
08/30/16 06:42 PM
ecoboost 3.5
by boostnation
08/30/16 06:30 PM
Meijer, Mobil and the joys of Labor Day stackation
by fdcg27
08/30/16 06:25 PM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
18 registered (AnthemBassMan, Atesz792, fonecord2, c502cid, 5 invisible), 639 Guests and 8 Spiders online.
58964 Members
66 Forums
253791 Topics
Page 2 of 5 < 1 2 3 4 5 >
#3407485 - 06/26/14 11:02 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
yvon_la Offline
Loc: quebec canada
Mm!you arent using bio?then you must be a city driver !your ll need thinner oil .5w40 oil are great oil anytime but when cold.if you do a lot of start and stop city driving .might want to switch to a blend like a 10w30 for big truck .if money isnt an issue you could try shell rotella t6 0w40 or mobil delvac1 le5w30 (all the one i mentionned are all big truck oil).no it doesnt have to be exactly those,they re just a reference for comparision .
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3410574 - 06/30/14 06:06 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Blasar]
JorgeMartins Offline
Loc: Portugal
Originally Posted By: Blasar
JorgeMartins,
As already said, besides the values of Fe, Al and Silicon, your UOA seems normal.
Try the OEM air filter, if you are using other brand, and shorten the OCI to see if the numbers go down a bit.
FWIW, I can confirm what was said about the directives being followed by the Portuguese branch of Renault, and I donīt take too serious what the auto magazines try to sell us, but thatīs another issue.
Regards.
Hi Blasar.
The air filter is almost new, and it's clean.
Thanks.
#3410575 - 06/30/14 06:08 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: yvon_la]
Loc: Portugal
Hi yvon_la,
60% city.
My car use Castrol Edge 5W40 it's the Renault recommended oil for this car.
Many thanks.
#3419158 - 07/09/14 05:37 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Blasar Offline
Loc: Portugal
If the air filter is OK and is the OEM recommended, and all the intake system is pristine, maybe shortening the OCI does do the trick, but is just a guess.
Regards.
Excuse my poor English.
#3419302 - 07/09/14 08:55 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Blasar]
Loc: Portugal
Regards.
Hi Blasar
Can you please be more specific about:
"OEM recommended"
"shortening the OCI"
Thanks.
#3420976 - 07/10/14 04:48 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
chrisri Offline
Loc: Fiume, EU
Does yor car have DPF? If not i would use Selenia WR 5w40 in this Megane. It's one of the best common rail engine oil for cars without DPF. And shorten your OCI to 10 k km or 1 year if you are doing alot of short trips. And you really don't need 5w30 in your hot/ moderate climate.
99 FIAT Punto Sporting 16v ( Shell Helix Ultra 5w40 )
06 FIAT Stilo MW 1.9 Multijet (Shell Helix Ultra 5w40)
#3421432 - 07/11/14 04:06 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: chrisri]
Loc: Portugal
Hi chrisri.
What is DPF?
My car uses Castrol Edge 5W40 not 5W30.
Thanks.
#3421490 - 07/11/14 07:15 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
chrisri Offline
Loc: Fiume, EU
Hi chrisri.
What is DPF?
Thanks. [/quote]
DPF= diesel particulate filter,an emission nonsense,but you probably don't have any in your Megane since you are using Edge 5w40. Some others recommended 5w30 oils and this is why i mention that grade.Stick with Castrol but keep your oil change interval under 10000 km.
#3424054 - 07/14/14 04:28 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Hi chrisri.
Thanks.
#3424217 - 07/14/14 09:41 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
yvon_la Offline
Loc: quebec canada
Diesel are usually bullet proof!check engine oil pump thread online,i dont know any diesel engine that need a big fix at 150k
Truck driver
#3424228 - 07/14/14 10:00 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: yvon_la]
Loc: Portugal
yvon_la,
You Know now, In Portugal Renault recommends changing the big end bearing on 1.5dci (Renault, Nissan and Dacia) between 100 and 150k!
If you google it, chectk on foruns or contact Renault stands it's easy to find.
#3424669 - 07/14/14 05:55 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
yvon_la Offline
Loc: quebec canada
I aint saying the bearing isnt an issue ,but usually oil pressure is the culprit.side note stuff like twin cam and variable ....is fairly new on the diesel world wouldnt surprise me if pressure of oil need to be 5 or 10 psi higher then it used too
Truck driver
#3425194 - 07/15/14 05:51 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
yvon_la,
yes some times i've heard about oil pressure too, but is just another teorie like others, not confirmed.
Thanks.
#3588930 - 01/05/15 09:36 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Hi there.
I've requested a second engine oil anaisys and I need some help to interpretate it based in the topic domain.
Renault Megane II Break 1.5 Dci, 105 hp from 2007. Diesel engine.
I change the oil at 15.000 Km intervals, and the oil i'm using is Castro Edge 5W30.
Many thanks.
#3598380 - 01/13/15 06:33 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Hi there.
Anyone??!
