Originally Posted By: yvon_la
This oil is made by valvoline or it is a copy.if i recall valvoline voa it is identical but this has moly http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1760810
So sorry to bust you bubble but nope ,no leak.sodium is one of the additive valvoline put
At the small amount we talk here ?it must be something like a bolt or if oil cooler is with rad .radiator is going off line
More trolling and stupidity from yvon.... At what point does it end?
so basicly you say there is no oil with high sodium count?(that was my point after all http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2270021 tell it to this post then
Again, this comes back to reading comprehension and learning the English language. Nobody said oil doesn't have sodium. Valvoline does. I run VSP myself. "Sorry to bust your bubble, but" you can't read. Learn, or get off the forum. Since you know everything, why don't you explain what potassium is?
