The Top Dexos2 Oil Available in the USA is What?
by Best F100
05/29/16 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
05/29/16 05:13 PM
The 17 year cicada is here. (locust) PIC HEAVY.
by Rand
05/29/16 04:23 PM
How long is sealed coolant good for?
by addyguy
05/29/16 04:08 PM
4T65E 2006 Buick Lucerne Normal decel gear banging
by deanm11
05/29/16 03:41 PM
California drought and 3" fish delta smelt
by HTSS_TR
05/29/16 03:18 PM
High SAPS & DPF Re-Gen
by userfriendly
05/29/16 02:50 PM
Decent little string trimmer
by Papa Bear
05/29/16 02:24 PM
Pirelli
by borgward
05/29/16 02:10 PM
'88 Cadillac smog (Emission test) fails
by momo
05/29/16 01:59 PM
Towing what to look for?
by Camprunner
05/29/16 01:48 PM
The Critic's Choice 2014 Yaris vs 2015 Accent
by Gasbuggy
05/29/16 12:52 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
76 registered (Al, bcossa2001, aquariuscsm, Bandito440, AandPDan, 2010Civic, 5 invisible), 1545 Guests and 319 Spiders online.
58013 Members
66 Forums
249569 Topics
#3422105 - 07/11/14 08:27 PM Delvac 1 SHC 5W40 Unimog 17.5kmi
m37charlie Offline
Loc: Alaska
All numbers not listed are zero or 1
Fe 36
Cu 3
Al 5
Si 3
Na 18 (same as VOA)
Mg 51
Ca 4634
P 1399
Zn 1487
Mo 2
B 294
Vi 13.6
Fuel <1%
Soot 0.7
Water <0.05%
TAN 3.85
TBN 12.4
Makeup oil 6.5L in 29L sump
Analysis done by Detroit Diesel in Portland
I changed not because I thought it was used up but because it had been 2.5 years.
Clearly I can go for very long OCIs.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#3422106 - 07/11/14 08:28 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
dparm Offline
Loc: Chicago, IL
Unimog eh? Can we see a pic of the beast?
2011 BMW M3 sedan ZCP
#3422117 - 07/11/14 08:41 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: dparm]
m37charlie Offline
Loc: Alaska
#3422151 - 07/11/14 09:18 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
901Memphis Offline
Loc: Northern Kentucky
I'd stretch it to 4 years and uoa for TAN. With that kind of make up oil you'll probably never run out of TBN.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3422244 - 07/11/14 10:53 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi Charlie,
a great UOA - yes, your OCIs could be extended too
My very kind regards - coming back to OZ anytime soon?
Regards
Doug
#3422247 - 07/11/14 10:57 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
m37charlie Offline
Loc: Alaska
Doug,
Not exactly soon but maybe after a generally eastwards trip through
Europe, Israel, Russia, Mongolia, China, SE Asia...
Shipping to and from Australia was more expensive than shipping to and from Europe by a factor of 10.
Charlie
#3422254 - 07/11/14 11:05 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
Hi Charlie,
I'm most envious - best wishes
Regards
Doug
#3422422 - 07/12/14 07:02 AM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
dnewton3 Offline
Loc: Indianapolis, IN
Charlie
I cannot agree with you any more than that!
Very low wear.
Very low contamination.
Excellent TBN/TAN relationship.
etc,etc ...
Extended OCIs are very much a reality here. 2.5 years and this is the result? Excellent example of how the clock is NOT a tool to change oil.
Obviously, Charlie is very-well versed in his application and will not extend without UOA confirmation along the way, but I see LONG OCIs if this is indicative of the performance.
This being the result, I would think even longer use would be something to consider.
Edited by dnewton3 (07/12/14 07:04 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3424214 - 07/14/14 09:33 AM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
m37charlie Offline
Loc: Alaska
I think my plan will be to sample this new oil change at 20K and then every 7.5-10K thereafter. The limiting factors could be Fe (the limit on the engine is 200ppm) or viscosity, I doubt it will be TBN.
Charlie
