Originally Posted By: beanoil
Originally Posted By: webfors
Which one would I use for the 2013 SFV650?
Well there is only one Bales adapter for Suzuki, and Honda has one filter that covers 99.9 percent of their bikes. The PH7317 and it's little brother the PH6607, (Honda/Nissan, other import apps) has the same thread size. Many Honda ST and Wing guys use the car filter for their bikes with no harm. I put the Bales adapter on a 600 GSX-R a while back. That rider is running a PH6607 because of header clearance issues. The point of the conversion is to get away from Suzuki's goofy thread size, and open up more common and less expensive filters for use.
I received my Suzuki filters and they remind me of the Subaru Tokyo Roki's from the past. Very well built, silicon ADBV, solid weight to them indicating significant pleating (which you can see through the top). I don't know what the efficiency ratings are for this filter however.
The only reason I would go with the adapter is to run a Fram Ultra.
