I've never seen this before, and couldn't find any info. My Impala's fuel gauge is a little quirky. WAIT, keep reading. It does NOT fluctuate while running. It only seems to fluctuate when the key is in the on position, but NOT running. And no, it's not because fuel is still sloshing around in the tank. When I check, it's always after the car has sat for 8 or more hours. It fluctuates no more than a 1/4 tank in either direction of the accurate level. I always run premium fuel without ethanol (91 tune) and frequently (every ~3k) use a bottle of Techron. What could this be and should I be concerned? Or is this a "if it ain't broke, don't fix it" type of thing (especially considering GM's history with fuel gauges)?
