Valvoline syn vs. dino in a power steering system
by Bottom_Feeder
07/26/16 02:51 PM
Pontiac G8 GT transmission deep pan upgrade...
by Blokey
07/26/16 02:17 PM
Hearing Aides
by CourierDriver
07/26/16 02:05 PM
SuperTech PS Fluid made my PS pump sound like new.
by BigD1
07/26/16 01:34 PM
Double clutching because of worn synchro?
by FordCapriDriver
07/26/16 01:29 PM
Titan single cab
by cptbarkey
07/26/16 01:11 PM
How to work dealers on price?
by Huie83
07/26/16 11:56 AM
MC FL820 6,000km's Cut Open
by Canadastang
07/26/16 11:28 AM
Loathing specific manufacturer for no reason
by FutureDoc
07/26/16 11:14 AM
Top Sirloin?
by totegoat
07/26/16 10:42 AM
Has anyone met a long distance friend?
by motor_oil_madman
07/26/16 10:21 AM
Daimler's MyTaxi
by Y_K
07/26/16 09:36 AM
lowsapsdieseloil, kit2523, rfabrocini, Tobin28, r0k
58600 Registered Users
110 registered (AIRJAC3, Alfred_B, 69GTX, adamrc, 2015_PSD, 13 invisible), 2061 Guests and 21 Spiders online.
58600 Members
66 Forums
252270 Topics
#3423766 - 07/13/14 07:34 PM Gumout Multi System Tuneup review
Drew99GT Offline
Loc: Colorado Springs
I took advantage of the FAR Gumout Multi System Tuneup at Advance Auto a month ago. Vehicle is a 1994 Toyota Corolla with 170,000 miles. These engines have piston rings problems where the oil control rings gum up and the engines consume oil. In my experience, after using various cleaners such as MMO, Auto-RX, Rislone etc., the oil consumption will go from 1,000 miles per quart to about 2,000 miles per quart, and after about 20,0000 miles, the rings get gummed up again.
With the Gumout product, I added 1 ounce per quart of oil to the oil, so 4 ounces in the crankcase, 6 ounces I used through the PVC line with the engine running, and 6 ounces in the fuel tank. After 500 miles, the oil hasn't budged on the dipstick and it's black with only 2,000 miles total on this interval. Seems to be doing something. I can't really comment on whether the engine runs better since prior to this, I did a full Seafoam treatment and ran about a half gallon of water through the PCV ;line to try and decarbon the engine. It ran great before the Gumout but I wanted to try it in the oil to see of it would do anything for oil consumption and it has. I did not run any Seafoam in the oil, just 1 can through the PCV line.
On a side note, the oil filter on the car currently is a Purolator Premium Plus L14476 that has withstood all of the above and the car sat for almost a year with intermittent driving since I work from home. This fall I'll be taking it off with probably 3,000 miles, and it's had the above Seafoam, water, and Gumout run through the engine and 2 brutally cold winters. We shall see what the media looks like! I'll post pics. cool
Edited by Drew99GT (07/13/14 07:36 PM)
#3423778 - 07/13/14 07:47 PM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
Trav Offline
Loc: MA, Mittelfranken.de
Cool. Site sponsor too! I will definitely try this on a few upcoming projects.
You cant have too many tools, another one that really works just broadens the possibilities for a successful clean up. thumbsup
#3423783 - 07/13/14 07:52 PM Re: Gumout Multi System Tuneup review [Re: Trav]
demarpaint Offline
Loc: NY
I'll be on the lookout for deals on it too.
God Bless Our Troops
#3423855 - 07/13/14 08:46 PM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
Drew99GT Offline
Another observation I took away when doing the 3 step process since I had a few drops spill out on my fingers when doing the PCV induction; it felts quite slippery like it has a lot of lubricity. Very different than Seafoam. Seafoam seems evaporative and volatile and not so oily.
#3423861 - 07/13/14 08:53 PM Re: Gumout Multi System Tuneup review [Re: Trav]
Drew99GT Offline
Heck yea! My Corolla is bordering on Gary Allen type experimentation at this point. The only 2 things I haven't run through the oil system, fuel system, or induction system are transmission fluid and Kreen! My next trial will be Rislone. I did use Rislone previously but at 1/2 the recommended dosage and it did slow oil consumption.
Prior to all of this additive usage, I believe I haven't done any type of oil system cleaning to try and get the rings free in several years. Roughly 60,000 miles ago I did used BG Quick Clean and that really helped slow consumption. I also used MMO at very reduced dosages.
Most people wouldn't notice anything, but on these older Corollas, 93-97 and 98-02, and even prior to 93, the didn't have enough drain holes drilled in the pistons for the oil control rings and oil bakes into them similar to older model Saturn engines.
Edited by Drew99GT (07/13/14 08:54 PM)
#3424235 - 07/14/14 10:14 AM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
Vikas Offline
Loc: NorthEast
when do you plan on doing OCI on this car and then monitoring the oil consumption? or would you be letting this oil run for few more thousand miles and watching the consumption?
I have 4 cans which I have no idea why I picked them but as Paul says, having more tools is always a good idea!
#3424355 - 07/14/14 12:19 PM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
Drew99GT Offline
I plan on changing the oil/filter this fall since it will have had 2 years on it. That will likely be about 1,000 miles with the gumout in the oil.
#3424400 - 07/14/14 01:16 PM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
demarpaint Offline
Loc: NY
Nice to see another low cost option for cleaning up an engine. Hopefully AAP or A-Zone will be running it on sale again so I can give it a try myself in a beater OPE engine I recently got.
#3424409 - 07/14/14 01:22 PM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
SatinSilver Offline
Loc: Ohio
Taste a few drops and report back... smile
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC 822 filter
#3425354 - 07/15/14 10:02 AM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
Mystic Offline
Loc: Colorado
Keep us informed how well this product works. All I care about is what works and for the least amount of money. If this Gumout product is the one we have been looking for, that is great.
People need a engine cleaning product for engine internals that will safely and as cheaply as possible get the job done.
#3718452 - 05/03/15 07:04 AM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
ET16 Offline
Loc: MD
I just bought some of this. I was wondering about its use in the oil of a turbocharged Saab. The web site says it is for use in all engines.
#3759546 - 06/13/15 08:14 PM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
buck91 Online   content
Loc: West Michigan
Any updates on oil consumption?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#4004007 - 02/08/16 02:10 PM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
Dominic Offline
Loc: Gilbertsville, PA
Any updates on this? (I know, old thread, it's been over 6 months.)
2014 Mazda 6 GT - M1 EP 0W-20
2008 Nissan Versa SL - Valvoline 5W-30 Synpower
#4004199 - 02/08/16 05:38 PM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
Pontual Offline
Loc: SANTOS, BR
I sent a pm to him, asking for the results...
#4004652 - 02/09/16 02:50 AM Re: Gumout Multi System Tuneup review [Re: Drew99GT]
Drew99GT Offline
Sorry for lack of updates. Yes, oil consumption did improve with the product and the car ran better after running the Gumout through the PCV line. However, I can not vouch for Gumout entirely or tell whether it is a longer term cure for cleaning out rings and combustion chambers because since using the product, I've also used Rislone in the oil and done a Seafoam induction cleaning last summer! The car in question is high mileage and suffers oil consumption and deposit related issues so routine cleaning is what I've done for many years now using a variety of products, all of which have shown positive results. I've used BG MOA, Seafoam, Rislone, and Gumout.
