Which Oil
by Jamn
06/29/16 02:11 AM
Oil for Binding Foundry Sand
by smw
06/29/16 01:38 AM
Found a good high zinc breakin oil
by 1977c10phxdriver
06/29/16 01:12 AM
What is this radio modulating sound?
by Pontual
06/29/16 01:00 AM
The reason brake fluid can be Dot 3&4 - Viscosity!
by CharlieBauer
06/29/16 12:56 AM
No injector pulse, '92 Prelude, F20B, GSR ECM
by redhat
06/29/16 12:02 AM
Finding #1 Cylinder
by motorguy222
06/28/16 11:31 PM
Sure Filter 2821A C&P
by funflyer
06/28/16 11:27 PM
Can Kies save multiple phone info?
by daves66nova
06/28/16 11:25 PM
Tie-Rod Brands? AcDelco, B&A, Mevotech, MOOG
by Mr_Accord
06/28/16 10:23 PM
Engineer and Frog
by Koop
06/28/16 09:05 PM
Chevy 6.2 Silverado, Shaffer's or Mobile 1
by Crobinson16
06/28/16 08:32 PM
dougsangster, CrazyCalvinW, mal86, smw, Crobinson16
58311 Registered Users
30 registered (c502cid, Boczech, Darris, BrianF, Chris B., carlprop, 3 invisible), 814 Guests and 21 Spiders online.
58311 Members
66 Forums
250964 Topics
#3422105 - 07/11/14 08:27 PM Delvac 1 SHC 5W40 Unimog 17.5kmi
m37charlie Offline
Loc: Alaska
All numbers not listed are zero or 1
Fe 36
Cu 3
Al 5
Si 3
Na 18 (same as VOA)
Mg 51
Ca 4634
P 1399
Zn 1487
Mo 2
B 294
Vi 13.6
Fuel <1%
Soot 0.7
Water <0.05%
TAN 3.85
TBN 12.4
Makeup oil 6.5L in 29L sump
Analysis done by Detroit Diesel in Portland
I changed not because I thought it was used up but because it had been 2.5 years.
Clearly I can go for very long OCIs.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#3422106 - 07/11/14 08:28 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
dparm Offline
Loc: Chicago, IL
Unimog eh? Can we see a pic of the beast?
2011 BMW M3 sedan ZCP
#3422117 - 07/11/14 08:41 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: dparm]
m37charlie Offline
Loc: Alaska
#3422151 - 07/11/14 09:18 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
901Memphis Offline
Loc: Northern Kentucky
I'd stretch it to 4 years and uoa for TAN. With that kind of make up oil you'll probably never run out of TBN.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3422244 - 07/11/14 10:53 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
Doug Hillary Online   content
Loc: Airlie Beach Australia
Hi Charlie,
a great UOA - yes, your OCIs could be extended too
My very kind regards - coming back to OZ anytime soon?
Regards
Doug
#3422247 - 07/11/14 10:57 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
m37charlie Offline
Loc: Alaska
Doug,
Not exactly soon but maybe after a generally eastwards trip through
Europe, Israel, Russia, Mongolia, China, SE Asia...
Shipping to and from Australia was more expensive than shipping to and from Europe by a factor of 10.
Charlie
#3422254 - 07/11/14 11:05 PM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
Hi Charlie,
I'm most envious - best wishes
Regards
Doug
#3422422 - 07/12/14 07:02 AM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
dnewton3 Offline
Loc: Indianapolis, IN
Charlie
I cannot agree with you any more than that!
Very low wear.
Very low contamination.
Excellent TBN/TAN relationship.
etc,etc ...
Extended OCIs are very much a reality here. 2.5 years and this is the result? Excellent example of how the clock is NOT a tool to change oil.
Obviously, Charlie is very-well versed in his application and will not extend without UOA confirmation along the way, but I see LONG OCIs if this is indicative of the performance.
This being the result, I would think even longer use would be something to consider.
Edited by dnewton3 (07/12/14 07:04 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3424214 - 07/14/14 09:33 AM Re: Delvac 1 SHC 5W40 Unimog 17.5kmi [Re: m37charlie]
m37charlie Offline
Loc: Alaska
I think my plan will be to sample this new oil change at 20K and then every 7.5-10K thereafter. The limiting factors could be Fe (the limit on the engine is 200ppm) or viscosity, I doubt it will be TBN.
Charlie
