Hi there
My first post, so go easy on the newbie please!!
About viscosity Index Improvers...
I understand the working mechanism of the VII to be that the polymer uncoils at increased temperature which effectively boosts the oil's apparent viscosity. Also, the greater the VII dosage, the greater the VI increase (wider viscosity stretch).
Therefore, I believe the lubricant grade can be formulated by using the correct amount of VII relating to the product, and then balancing the base oils to achieve the target lube viscosity (cSt at 100degC using standard tests).
However, manufacturer's recommendations for treat rates is limited, my enquiries to them have been rather frustrating, and I've turned up little of assistance on google. Hence I'm appealing to the board for assistance in my understanding of application of VII to wider grades!
For instance, one well known manufacturer produces a copolymer in solid form, which it recommends to dose at 12.5%wt into SN150 base to produce a VII masterbatch.
It then provides treat rates as follows:
5W-30: 10-11%
10W-30: 9-10%
10W-40: 10-11%
15W-40: 8-9%
20W-40: 7.5-8.5%
This is ok, and I get the general idea. But what is the science behind it? How does it relate to J300? Is the treat rate % related to the resulting viscosity index of the finished blend?
I would rather understand how to calculate (rather than guess) the treat rates for eg. 20W-20, 20W-50, 0W-30, etc. etc.
Also what about treat rates for multigrade gear oils, eg 80W-90 and 85W-140.
Finally, regarding base oil blending, I've discovered that applying the masterbatch V100 as 1,450cSt (per manufacuter's data) to the tested base oil blends (say SN150~5 & SN500~11) - the theoretical viscosity (from weighted average logarithms) gives a very good approximation to the tested viscosity. So I must be doing something right!!!
Thanks in advance for any input.
Best Regards, Marcus
5W-30: 10-11%
10W-30: 9-10%
10W-40: 10-11%
15W-40: 8-9%
20W-40: 7.5-8.5%
