73 beetle keeps blowing signal fuse
Virginia Bch. VA
Hi all, looking for VW guru's.
At the collision center I work at we just repainted a mint condition 73 Super beetle with only 53K orig miles. When I say this car is mint, its truly MINT! Original owner and completely unmolested since new. Full service history since 73'. Original everything in perfect condition. Its literally a little old mans car. Its his pride and joy.
Anyway, it keeps blowing fuse number 12 as soon as you turn on the signals. I'm thinking its a ground on either the front or rear signal lamps. Also when turning on the hazards it pops that fuse too.
Any ideas?
Thanks.
Certainly, a grounded power wire could cause it. Another possibility is a melted filament in a bulb. Pull the bulbs out, hit the switch, and see if the fuse still blows. Yes? Look for a wiring issue. No? Replace the bad bulb.
I would take the 32mm nut off, behind the horn, and check all the wiring going to the turn signal. I would bet that there is one wire that is rubbing.
