Happy Birthday Merkava_4
by Trav
05/03/16 04:56 PM
When should you use grease with moly?
by Jetstreamz06
05/03/16 04:54 PM
VOA Motul 4100 Power 15W50
by GermanAutohaus
05/03/16 04:31 PM
Ace Hardware Pennzoil Yellow May 4th to 9th $2.99
by BigD1
05/03/16 04:23 PM
How often to get tires balanced?
by 2010Civic
05/03/16 03:17 PM
Manual says every 10 K on oil changes
by ceast
05/03/16 02:42 PM
Brake fluid ageing?
by LucasDK
05/03/16 02:39 PM
If Anybody has 60K Lying around
by GumbyJarvis
05/03/16 02:03 PM
144$ lot of 48 Fl-400s/L20195 Eq Filters
by GumbyJarvis
05/03/16 01:29 PM
AT Whine
by DWC28
05/03/16 01:14 PM
GM AutoTrak II fluid
by nthach
05/03/16 12:49 PM
GM 2500HD 75w-90 or 75w-110
by Stewart Fan
05/03/16 12:03 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
85 registered (ag_ghost, 2015_PSD, 69GTX, 2oldtommy, 901Memphis, 12 invisible), 1807 Guests and 270 Spiders online.
57779 Members
66 Forums
248418 Topics
Page 1 of 2 1 2 >
#3418093 - 07/08/14 10:46 AM 95+ degree travel
opus Offline
Loc: Montana
Have a 1993 Suburban with a 200k, 350 engine. Got a trip from MT to NV next week, lots of up and down and going to be hot. Currently run 10/40w. With temps that high I sure would like to keep the oil viscosity up. Lots of mountains, etc.
I thought Lucas Oil Stabilizer but I see it gets no love here. Any other suggestions? Add a quart of straight weight to the oil change?
What think ye?
#3418096 - 07/08/14 10:48 AM Re: 95+ degree travel [Re: opus]
Miller88 Offline
Loc: Onondaga County
No. Do not use the Lucas. It's just heavy, detergentless oil.
I wouldn't be concerned about the 10w-40 in it. If it's that hot, make sure your radiator hoses are up to par.
Leave what's in there.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#3418104 - 07/08/14 10:58 AM Re: 95+ degree travel [Re: opus]
Oil Changer Offline
Loc: Michigan
You will be fine with the 10W-40. If you're itchin' to change the oil before the trip, your choices are almost limitless. SAE 30 or 40, an HDEO 10W-30 like Rotella T5 or Delo. 5 or 15W40 HDEO, an HM 10W30 or 40...like I said, endless. Skip the Lucas. That's what I think.
#3418106 - 07/08/14 10:59 AM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
I'll surely skip the Lucas.
You know as well as I do that the oil is going to be water thin after 700+ miles in that weather. I'd have thought a little straight weight would be a good thing.
Radiators, etc are good to go.
Edited by opus (07/08/14 11:00 AM)
#3418110 - 07/08/14 11:01 AM Re: 95+ degree travel [Re: opus]
Barkleymut Offline
Loc: Richmond, VA
you will be fine. I drive in mid 90's all summer and never have a problem. Just make sure the radiator is clean and in good shape. The only concern I would have is if you are doing much stop and go driving which I would guess you are not.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#3418111 - 07/08/14 11:02 AM Re: 95+ degree travel [Re: opus]
JayhawkRoy Online   content
Loc: Basehor, KS
Leave things alone. Take some extra coolant and oil with you, just in case, along with whatever normal emergency stuff you carry. The oil you are running will do fine.
Check your oil level daily during the all day driving runs. I prefer a morning and then mid-day oil level check, just to make sure.
Edited by JayhawkRoy (07/08/14 11:03 AM)
#3418112 - 07/08/14 11:02 AM Re: 95+ degree travel [Re: opus]
rockydee Offline
Loc: VA
If your cooling system is good you have nothing to worry about. Leave the Lucas at your local supplier.
#3418119 - 07/08/14 11:06 AM Re: 95+ degree travel [Re: opus]
Oil Changer Offline
Loc: Michigan
No, it will be 30 or 40 grade thin depending on if you put 30 or 40 grade in after 700+ miles in that weather.
As others have already alluded, your brakes, cooling system, and other sub-systems are more important than what's in the oil pan; provided that you are using a quality oil, which I'm sure you are.
#3418124 - 07/08/14 11:11 AM Re: 95+ degree travel [Re: opus]
OVERKILL Online   content
Loc: Ontario, Canada
The oil is not going to be water thin, it'll stabilize at some temperature and stay about the same visc at some point early in the trip. You may thin it a bit more with some heavy-footed hill ascents but you won't know how much unless you are tracking OP/OT with some gauges.
Considering that engine originally spec'd an xW-30 that the OEM would have done extensive testing with, and you've already gone up a grade from there, I don't see a need to be fretting about this.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3418127 - 07/08/14 11:12 AM Re: 95+ degree travel [Re: OVERKILL]
opus Offline
Loc: Montana
Well then, thats covered. smile
Thanks for the input.
#3418144 - 07/08/14 11:32 AM Re: 95+ degree travel [Re: opus]
Turk Offline
Loc: MN
When is the last time you changed the Coolant?
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3418159 - 07/08/14 11:50 AM Re: 95+ degree travel [Re: Miller88]
dave5358 Offline
Loc: North Bend
Originally Posted By: Miller88
No. Do not use the Lucas. It's just heavy, detergentless oil. I wouldn't be concerned about the 10w-40 in it. If it's that hot, make sure your radiator hoses are up to par.
+1. Forget the Lucas. Check your cooling system.
You did not indicate what oil you are using. At your next oil change, you might switch to a good synthetic (e.g. Mobil-1). It should be able to withstand any heat issues your engine might generate.
2006 Forester XT
2008 Corolla LE
#3418181 - 07/08/14 12:22 PM Re: 95+ degree travel [Re: opus]
dparm Online   content
Loc: Chicago, IL
Your car is not air cooled. No need to change your oil or go thicker.
Just make sure the car's cooling system is in good working order.
2011 BMW M3 sedan ZCP
#3418206 - 07/08/14 12:45 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
Coolant...you're supposed to change coolant?? wink
Synthetic, not with this many miles on it. It'll all end up on the ground probably.
#3418214 - 07/08/14 12:51 PM Re: 95+ degree travel [Re: opus]
Barkleymut Offline
Loc: Richmond, VA
This thread is far from done smile I would at least inspect the hoses and visually check the coolant.
Page 1 of 2 1 2 >
