OK, Nick...
Is your point that the asphalt on tracks is substantially different than the asphalt on roads?
Do you think that test tracks built to replicate road conditions are built differently, using different materials, than roads?
In many ways, roads are worse. The test track doesn't have the oil/fuel in the surface that ordinary roads collect from the jalopies driven on them...and the test track doesn't have the settling of surfaces that leads to puddling. The tracks are built for uniform surface and depth so that tests are measurable and repeatable.
That means that regular roads are even more slick, and more prone to puddling, and more unpredictable than the tire testing tracks...
