I am getting ready to clean the throttle body, MAF and replace the PCV value on an 90 Camry (2AZ-FE) as a firt attempt to remedy an intermittent rough idle problem. What cleaner should I use on the throttle body? I will be using an electronics spray cleaner on the MAF.
