Originally Posted By: ram_man
Originally Posted By: bdcardinal
Just visually inspect and look for cracks in the anti-sway bar bushing. Ford has some models where the bushing is only serviced in the complete anti-sway bar.
For the end-links, the bushing type gets a visual inspection, the ball joint style gets visual inspection for torn boots and then checked for excessive movement.
Would you replace a ball joint for a cracked or torn boots but having zero play?
Yes.
It might have zero play now, but how will it be in a few weeks after dirt from the road has done its thing to it?
