Originally Posted By: boundarylayer
Originally Posted By: R_W_M
I don't have any experience with that particular brand, but I have used Fumoto oil drain valves in my last 4 vehicles and recommend them highly. High quality, solid brass body with stainless steel ball valve. I think that the last one I bought cost in the $35-40 range.
http://www.fumotousa.com/
Is brass the best to use here? Too soft. Stainless steel would be better I'd think. Anyway, I do like the Fumoto idea. I've been using magnetic drain plugs. A strong magnet one:
http://www.goldplug.com/ Some other brands have a weak, ineffective magnet, be careful which one you get. I like the Fumoto easy-drain method, yet me wants magnetic to pick up iron particles that might be small enough to make it through the oil filter.
Fumoto valves are approved by several vehicle and engine manufacturers including Cummins, Peterbilt, Caterpillar, Nissan, Mitsubishi, Toyota, Mazda, Subaru, Case, Toro, Kenworth, Damlier, Lincoln Electric, and a few others. Fumoto uses the same brass body on the valves they build for the big boys, as they do for the valve that is on my Subaru. If it is good enough for a Cummins or a Caterpillar, it is good enough for all our puny little engines.
