08 caravan / oil seeping from spark plug
by Mark72
02/12/16 11:25 PM
Holley Accelerator pump probem
by nwjones18
02/12/16 10:56 PM
Sealant for threaded air hose fittings.
by BigD1
02/12/16 10:37 PM
on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
Left my lights on and battery died.
by joegreen
02/12/16 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
02/12/16 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
02/12/16 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
02/12/16 06:54 PM
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
49 registered (anonobomber, 2015_PSD, AdRock, 01_celica_gt, 87sammy, 1345, 7 invisible), 704 Guests and 99 Spiders online.
56902 Members
66 Forums
244626 Topics
#3414297 - 07/04/14 09:08 AM wheels between ford and olds?
buck91 Online   content
Loc: West Michigan
One is a 5 on 114.3mm and the other is 5 on 115mm. Assuming offset and diameter is close enough will this work?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#3414315 - 07/04/14 09:30 AM Re: wheels between ford and olds? [Re: buck91]
bigjl Offline
Loc: London, England
I think they would go with wobble bolts.
I have never used them but have heard about them.
10 BMW 116D SE 110k miles Full BMW Hx
12 Jaguar XJL 3.0 D Luxury 132k 5w30 Shell AF-L
#3414316 - 07/04/14 09:31 AM Re: wheels between ford and olds? [Re: buck91]
Klutch9 Offline
Loc: Rochester, MI, US, World
Not a good idea. Can it be 'done'? Sure, and you'll find people online who have done it. But think about how that .7mm difference on each stud will affect the lug nut-to-wheel seating. In other words, none of them will seat flush, so only a portion of the lug nut's seating flange will be pressing on the wheel's flange. This puts high stress in one spot from all that torque, for each lug nut and each area where they seat. Don't risk it. If one would fail, you or other people could die. As to why these 2 extremely similar lug spacing standards exist, I have no idea. Kind of like the metric wheel sizes back in the 70's.
'11 Fusion 2.5L - 55k miles - Napa 0w20, Fram TG filter
'08 Sedona LWB 3.8L - 91k miles - Napa 0w20, K&N PS filter
#3414325 - 07/04/14 09:52 AM Re: wheels between ford and olds? [Re: buck91]
loyd Offline
Loc: California
One of those wheel is 5 on 4.5 inches and the other is metric! Why would you want to do something so UNSAFE?
#3414432 - 07/04/14 11:51 AM Re: wheels between ford and olds? [Re: buck91]
Traction Offline
Loc: iowa
BAD IDEA! Just because they will fit doesn't make it right. I have ran into this before. If 2 studs don't twist right off when you remove the lug nut, they will when you torque them. And your wheels will wobble. I hate it when some people try and re-invent the wheel.
#3414513 - 07/04/14 01:20 PM Re: wheels between ford and olds? [Re: buck91]
2oldtommy Offline
Loc: Ohio
Salvage yard wheels are cheap. Do it. FWIW
Oldtommy
#3414517 - 07/04/14 01:24 PM Re: wheels between ford and olds? [Re: buck91]
Traction Offline
Loc: iowa
People have also tried to interchange 4.75 in.(120.65mm) and 120mm bolt circle wheels. Wrong!!! And the hubs will certainly not match.
The only bolt circle that is a match, is the 4.25 in. and 108mm.
Edited by Traction (07/04/14 01:25 PM)
#3414586 - 07/04/14 02:44 PM Re: wheels between ford and olds? [Re: buck91]
Loc: West Michigan
Good feedback. Havent tried it and now im confortable with that decision
2011 F150 4x4 5.0L
1980 Yamaha XS850G
