What HDEO oils do crab fishing boats use?
by car51
20 minutes 23 seconds ago
Hornet nest
by sleepery
Today at 03:28 PM
Valvoline syn vs. dino in a power steering system
by Bottom_Feeder
Today at 02:51 PM
Pontiac G8 GT transmission deep pan upgrade...
by Blokey
Today at 02:17 PM
Hearing Aides
by CourierDriver
Today at 02:05 PM
SuperTech PS Fluid made my PS pump sound like new.
by BigD1
Today at 01:34 PM
Double clutching because of worn synchro?
by FordCapriDriver
Today at 01:29 PM
Titan single cab
by cptbarkey
Today at 01:11 PM
How to work dealers on price?
by Huie83
Today at 11:56 AM
MC FL820 6,000km's Cut Open
by Canadastang
Today at 11:28 AM
Loathing specific manufacturer for no reason
by FutureDoc
Today at 11:14 AM
Top Sirloin?
by totegoat
Today at 10:42 AM
lowsapsdieseloil, kit2523, rfabrocini, Tobin28, r0k
58600 Registered Users
92 registered (AKA, 2015_PSD, 97prizm, Al, AIRJAC3, 10 invisible), 1975 Guests and 22 Spiders online.
58600 Members
66 Forums
252273 Topics
#3414182 - 07/04/14 06:23 AM 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP
AndrewD Offline
Loc: San Jose CA
This car has the smallest sump size of any car I've owned. 3.7 quarts w/ filter.
Would any adverse effects come out of running a EP oil for 15K OCI on a Honda filter? I'd also appreciate any opinions on M1 vs Castrol in 5w-20.
150k miles
1991 M5 - Kendall 20W-50
1995 525i/5 Kendall 20W-50
#3414214 - 07/04/14 07:35 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
gregk24 Offline
Loc: FL, USA
What type of driving do you do? If its all short trips, there is no way I would run a 15K OCI. If you get it up to temp every now and then, go for it! I would recommend the Fram Ultra for such a long OCI. It is rated at 15K and is available for under $9 at WM. As far as M1 vs Castrol...both will do the job, but I would prefer the M1.
2012 Honda Accord EX-L
Taffeta White - Ivory
39,xxx miles
PPPP 0w20 / Fram Ultra
#3414264 - 07/04/14 08:25 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
Tmiller3063 Offline
Loc: Georgia
I would suggest running the OCI called for in the manual first, 7,500 mi. Then do a UOA to see if you could extend it from there. I would run M1, that is my preference but either would do fine.
Edited by Tmiller3063 (07/04/14 08:28 AM)
2013 Honda CRV: Honda Genuine
2004 Toyota Tacoma: Castrol Syn Blend
1997 Honda Civic: Castrol Syn Blend
Oil Filters
15400-PLM-A01
90915-YZZD1
#3414300 - 07/04/14 09:11 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
Happy Birthday volk06 Offline
Loc: Iowa
EDGE EP. It has a stronger additive package, stronger TBN, and better results in a TEOST comparison.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3414304 - 07/04/14 09:15 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
Mr Nice Offline
Loc: Orlando, FL
My dad has the same car.
4 quarts of Mobil 1.
2007 Civic EX
2006 Accord SE
2005 RSX base
#3414352 - 07/04/14 10:22 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
bigt61 Offline
Loc: Virginia
The Honda filter will go 15k no problem. You could probably get away with 15k on the oil if you do a lot of highway driving, if not, stay at 10k. In both cases make sure to keep that baby topped off if it's using some along the way...which is likely. Both oils are fine. California, in general, is easy on oil....stuck in traffic on the 405 an exception.
92 Suburban 2500 7.4L 58k M1_5w30 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 29k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#3414402 - 07/04/14 11:22 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
ThirdeYe Offline
Loc: Walker, MI
My girlfriend has a 2001 with the same engine and it seems to be very easy on oil. Putting in 3.5 quarts (instead of the recommended 3.7) brings it right up to the full line for me. We haven't had it for very long but we plan to change it every 5,000 miles with a name brand 5W-20 that's on sale. We did the first oil change at 3,000 miles since it was in there for 8 months. First oil change was with Gulf 5W-20 from the dealer and the 2nd was done with Quaker State 5W-20. I believe Honda recommends changing the filter every other oil change, so I'd think 15k would be do-able if the conditions are right.
99 Pontiac Firebird - 93k - Havoline 10W-30/Purolator PureOne PL10111
08 Scion tC - 122k - Pennzoil Platinum 5W-20/Fram XG4967
#3414489 - 07/04/14 12:54 PM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
Mr Nice Offline
Loc: Orlando, FL
Tighten the gas pedal cable as these cars have lots of slack.
2007 Civic EX
2006 Accord SE
2005 RSX base
#3414635 - 07/04/14 04:03 PM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
AndrewD Offline
Loc: San Jose CA
Thanks all.
I do about 50/50 stop-n-go and freeway driving. It will get up to operating temperature at least once daily.
I think I will go with the Castrol Edge EP (gold bottle) for a 10k OCI and then perhaps a UOA when time comes. I will be sure to share it with you all if that happens.
#3415102 - 07/05/14 09:03 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
virginoil Offline
Loc: western australia
150k miles
Usually when you extend the OCI you change the oil filter so that you can add more fresh engine oil (without dropping the sump oil) when you top up and thus replenish the additives.
Vehicle OEMs usually increase sump capacity despite what Mobil Castrol or others claim just by using a specific oil in the lineup or brand for extended drain.
If your vehicle is not designed for extended OCIs I would err on the side of caution and follow the maximum allowable under the OEM recommendations for the given driving conditions.
Oil is cheap and now days it is recyled.
Edited by virginoil (07/05/14 09:12 AM)
Arriverdici e buona sera
#3415798 - 07/06/14 12:34 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
AndrewD Offline
Loc: San Jose CA
Thanks, owners manual states 10k / 1yr under "normal" conditions.
#3415847 - 07/06/14 06:24 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
DuckRyder Offline
Loc: Atlanta
It also says filter every other change (20,000).
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
  • 2012 Volkswagen Jetta TDi
#3521484 - 10/26/14 06:07 AM Re: 02 Civic LX D17A1 - Mobil 1 EP vs. Castrol Edge EP [Re: AndrewD]
AndrewD Offline
Loc: San Jose CA
I have gone 14,250 miles on the Castrol 5W-20 EP (1/2qt added) / BOSCH 3323 filter since July. I just serviced them with Mobil 1 5W-20 EP / Honda OE (Toyo Roki)and plan to go at least 12,500 on this combo. I will post the Blackstone results for the Castrol when it comes in.
