Lubrication Engineers vs Schaeffer's
by Dad2leia
05/04/16 05:49 PM
Tesla reports a worse than expected loss $282.3m
by Nate1979
05/04/16 05:27 PM
Using P/S fluid in a system that takes ATF ok?
by gregk24
05/04/16 05:24 PM
Redoing an old retrofit job headlights please help
by OtisBlkR1
05/04/16 05:19 PM
Mobil at Walmart + Mobil Rebate + Ibotta= $1/quart
by macarose
05/04/16 05:13 PM
Case 2470 tractor oil filters has slits
by njohnson
05/04/16 05:09 PM
Neglected Can Am Spyder
by Panzerman
05/04/16 04:22 PM
Considering a new Lexus ES - Durability?
by David_Corbett
05/04/16 04:02 PM
2016 Audi S4 Factory Fill UOA at 3,793 Miles
by CrazyJeeper
05/04/16 03:25 PM
epoxy to secure asphalt shingle?
by Digital2k2
05/04/16 03:21 PM
$75 Seized engine
by demarpaint
05/04/16 03:19 PM
Question on a VIN number..
by dblshock
05/04/16 03:18 PM
NatedeScate, Bogie69, Cali, Fyko, Palmer
57794 Registered Users
95 registered (AandPDan, 69GTX, 1JZ_E46, Al, 11 invisible), 0 Guests and 1 Spider online.
57794 Members
66 Forums
248471 Topics
#3414123 - 07/04/14 12:39 AM what gear oil for 1930 model A transmission?
Cjsporl Offline
Loc: New Jersey
Hey guys I'm wondering what I should be putting in a 1930 Model A transmission and differential. Trans and Differential are original. but the gearbox grinds pretty bad at this point. Any recommendations?
#3414134 - 07/04/14 12:59 AM Re: what gear oil for 1930 model A transmission? [Re: Cjsporl]
FL_Rob Offline
Loc: gulf coast FL.U.S.
Check this out,i'm sure you're already a member here,though.Very interesting stuff.
www.mafca.com/tqa_m_lubrication.html
#3414439 - 07/04/14 11:58 AM Re: what gear oil for 1930 model A transmission? [Re: Cjsporl]
4wheeldog Offline
Loc: East Mountains, NM
I wonder if anyone has tried Redline shockproof Heavy in this application?
#3414589 - 07/04/14 02:48 PM Re: what gear oil for 1930 model A transmission? [Re: Cjsporl]
MolaKule Offline
Loc: Iowegia - USA
I would use SuperTech non-synthetic 75W140 unless Amalie has something for it.
I would not use a synthetic in either unit unless I knew all of the seals had been upgraded with modern seals.
Edited by MolaKule (07/04/14 03:00 PM)
Stop worrying about what you have to lose and start focusing on what you have to gain. smile
#3414652 - 07/04/14 04:26 PM Re: what gear oil for 1930 model A transmission? [Re: Cjsporl]
38Chevy454 Offline
Loc: Albuquerque, NM
The trans is non-synchro, it will always grind some. I think any std 80W-90 type gear oil is fine, or the 75w-140 as suggested. It is just not a real critical application.
Edited by 38Chevy454 (07/04/14 04:29 PM)
