Heard of Hemi Tick- is there "Hemi Shudder"?
by JennyHemi
16 minutes 38 seconds ago
Lost my mind, about to buy Genesis Coupe 3.8
by FutureDoc
56 minutes 42 seconds ago
Tire Sizing Help
by coopns
Today at 10:23 AM
Update on AFE 0W20
by SubieMovie
Today at 10:17 AM
6th Gen Camaro SS LT1 Dexos2 Oil for Track
by thescreensavers
Today at 09:42 AM
MK7 GTI
by thr_wedge
Today at 08:41 AM
Real Motorcycle Dealers vs. "Power Sports" Dealers
by LoneRanger
Today at 07:50 AM
Our Sony 5 disk changer DVD player
by Oldmoparguy1
Today at 07:41 AM
JASO vs. Auto Oil for non-wet clutch Powersports
by coachvonyo
Today at 07:31 AM
Why Does Some Oil in Engine Smell "Worse"?
by Miller88
Today at 07:28 AM
Kevlar covered v-belt question.
by mrsilv04
Today at 07:06 AM
1991 yamaha xt600 NY registration questions.
by joegreen
Today at 06:18 AM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
92 registered (aquariuscsm, 69GTX, another Todd, ARCOgraphite, Al, 13 invisible), 1817 Guests and 318 Spiders online.
57779 Members
66 Forums
248404 Topics
#3412873 - 07/02/14 08:00 PM 1984 Mercedes 300td metal in oil
Volv04Life Offline
Loc: Virginia
I just changed my oil to find a few big metal pieces and a bunch of flakes in the oil. The pices looked like tiny curled up spirals but the were thick. I used a new pan so I crossed that out. The engine doesnt smoke or knock and my oil pressure gauge says it still has great pressure at idle and at speed. Also the turbo is in great shape as well. I checked the filter and there wasnt really anything in it. I didnt think to see if the metal was magnetic. Any ideas?
05 Nissan Altima 3.5 - Motorcraft/ Fram Filter
#3412897 - 07/02/14 08:17 PM Re: 1984 Mercedes 300td metal in oil [Re: Volv04Life]
artificialist Offline
Loc: Florida
Perhaps the timing chain or hardware related to the chain? I remember having someone come in with a failed timing chain and hardware on their ford modular, and behind the timing cover was so much metallic junk, that I was stunned the engine was still alive.
Garbage like that is often too big to pass through the oil pump screen, that may be why you didn't see anything abnormal in the oil filter.
A failing timing chain on a gasoline engine often sounds like a terrible diesel engine. Since you already have a diesel engine, you might not be able to notice that sound.
2010 Lancer Ralliart Sportback
#3412959 - 07/02/14 09:17 PM Re: 1984 Mercedes 300td metal in oil [Re: Volv04Life]
andyd Offline
Loc: Marshfield , MA
Wild guess, they are pieces scraped off the oil drain threads, You need a new drain plug.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3412997 - 07/02/14 09:59 PM Re: 1984 Mercedes 300td metal in oil [Re: artificialist]
Volv04Life Offline
Loc: Virginia
My altima 3.5 timing chain makes that noise for about a minute on start up and youre right, it does sound like diesel clatter. I couldnt tell if the chain on the mercedes is bad because its always loud and clattery.
#3413002 - 07/02/14 10:03 PM Re: 1984 Mercedes 300td metal in oil [Re: andyd]
Volv04Life Offline
Loc: Virginia
Thats possible. Ill have to pull the plug back out. I do remember seeing something odd on the drain plug but I completely forgot about it once i started seeing the pieces dropping out of the pain. It looked like chunks of sludge so I was stunned watching the oil drain and the interuptions in the flow of oil. The engine is spotless inside as far as I knew with no sludge so i freaked out seeing it.
#3421279 - 07/10/14 09:31 PM Re: 1984 Mercedes 300td metal in oil [Re: Volv04Life]
thrace Offline
Loc: USA
Could be anything. The Vacuum pump is not found in a gas car and sometimes loses the balls in the bearing. You would start checking the vacuum pump by removing it and looking if all the bearing balls are intact. Balls might fall out without total loss of vacuum. If it is the vacuum pump bearing, check for timing chain damage.
